newb question about engine specs
i'm not up on engine specs for H series motors. i need to know the following:
engine cast for H22 and H23 (ex. - B18C = P72)
stroke for H22 (is it 91 or 92mm?)
rod length for H22
stroke for H23 (is it 95 or 96mm?)
rod length for H23
i'm think the strokes are 91mm and 95mm respectively, but 92mm and 96mm would make a more proper 2.2L and 2.3L. but specs don't always turn out like we think they should.
rod length for H22
rod length for H23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.425 ownz 3.504!! »</TD></TR><TR><TD CLASS="quote">i'm not up on engine specs for H series motors. i need to know the following:
rod length for H22
rod length for H23
H22A1 and 91-96 JDM H22a = p13
H22A4 and 97+ JDM H22a = P5M
H22A4 Type-SH and JDM H22a Type-s = P5P
H22a Stroke 90.7 mm = 2.157L
Rod Length = 143mm
H23a stroke = 95mm = 2.258L
Rod Length = 141.5mm
rod length for H22
rod length for H23
Rod Length = 143mm
sweet. thanks brotha!
EDIT: why would there be a different casting for H22 motors? shouldn't it be the same casting? i know the engine codes will be different, but the casting should be the same. and whats the casting for the H23?
Modified by 3.433 ownz 3.504!! at 11:22 PM 6/29/2004
Modified by 3.433 ownz 3.504!! at 11:23 PM 6/29/2004
SUB-0 H23
Nov 4, 2004 03:56 PM
