Need advice??
Old Apr 10, 2004 | 11:42 AM
mini-v-si's Avatar
Default Need advice??
my car does not run the same ever since my distributor came loose becuase I forgot to tighten it. It was in the garage for a week until my friend came over and we adjust the timing because it jumped over couple teeth. Now my car is running but doesnt seem to run the same. My v-tec doesn't kick at 4500 rpm anymore it used too with the chip
Mods are 96 gsr with
skunk 2 cam gears
skunk 2 cams
Aem cold air
DC header/exhuast
P 28 with skunk 2 chip
any advice on what I should check??? or should I just take it in for a tune up.
Old Apr 10, 2004 | 02:21 PM
SIK IN DA HED's Avatar
New User
what you need to do is get it timed back to specs and get it running right.
DocIowa's Avatar
My guess is you severly screwed up the timing. If the timing belt 'jumped over a couple of teeth' did you take the timing belt back off and set your cam's back to TDC? If not, that's part of your problem too.
I'd take 'er in for a tune up and new belt.
Old Apr 10, 2004 | 02:50 PM
mini-v-si's Avatar
Default Re: (DocIowa)
yes cams are set back to tdc, but doesnt run the same...could a new belt solve the problem, what are other consideration???
boomersz
Apr 5, 2007 11:14 PM
boomersz
Apr 5, 2007 09:33 PM
Excelerate
13
May 12, 2004 04:31 PM
AK94GSR
May 25, 2002 08:36 AM
crx(gator)
Mar 4, 2002 07:53 PM
