modified distributor cap
Old Aug 21, 2003 | 03:11 PM
dominate9's Avatar
Default modified distributor cap
Who makes modified distributor caps for Preludes? I want to run an ignition system with an external coil?
Old Aug 21, 2003 | 03:27 PM
alphajesse's Avatar
Unless you have JDM I'm sure that your H22 has an external coil already.
JDMs might be external coil, too, but I don't know for sure.
Old Aug 21, 2003 | 03:42 PM
dominate9's Avatar
I have a JDM motor and all JDM motors have internal coils.
Old Aug 21, 2003 | 04:18 PM
dominate9's Avatar
Never thought of doing that. However, that will be more expensuve than just buying a cap for it. That's why I'm looking for a cap first
Old Aug 21, 2003 | 04:44 PM
SuperSH's Avatar
The usdm F22 runs a internal coil cap that will fit your JDM internal coil H22 distrubitor if all your looking for is a replcement. Unless you want one of those cute colored clear ones.
Old Aug 21, 2003 | 04:58 PM
dominate9's Avatar
Default Re: (SuperSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSH &raquo;</TD></TR><TR><TD CLASS="quote">The usdm F22 runs a internal coil cap that will fit your JDM internal coil H22 distrubitor if all your looking for is a replcement. Unless you want one of those cute colored clear ones.</TD></TR></TABLE>
I want to run an external coil. My engine has an internal coil. I am looking for a company that makes a cap that I can use with the external coil
Old Aug 21, 2003 | 07:36 PM
Gabe's Avatar
Default Re: (dominate9)
It's been a few years but I'm pretty sure that the replacement cap that I bought was a Crane cap (they list a cap for the H22 on their site). It works fine but it is not that different than the stock cap so I suggest that you buy whichever one is cheaper. For me it was the Crane cap.
Gabe
Old Aug 21, 2003 | 11:12 PM
EGPrelude's Avatar
i think MSD sells just the ignition coil tower to plug into your stock distributor. basically you have to drill a hole in your cap and screw in the tower and you plug the external ignition coil into that
Old Aug 22, 2003 | 09:52 AM
dvp95's Avatar
Default Re: (EGPrelude)
I have a 98 jdm h22, purchased the msd digital6+ and ss coil. I just purchased the usdm 98 lude cap from honda and converted it.
Old Aug 22, 2003 | 01:06 PM
spoolinlude's Avatar
I live under a rock
Default Re: (dvp95)
Just get electromotive like me and get rid of the whole thing entirely
Old Aug 23, 2003 | 08:32 AM
mikeaagesen's Avatar
Default Re: (spoolinlude)
So you run no distributor? Can i get more info on that? Does it have any advantages?
Old Aug 23, 2003 | 04:50 PM
I live under a rock
Default Re: (mikeaagesen)
http://www.electromotive.com read up on it, if you want more info let me know
Old Aug 24, 2003 | 11:35 AM
its like a place that sells stuff... which part do i go to?
Old Aug 24, 2003 | 03:37 PM
I live under a rock
Naa thats the actual manufacturers website.......... just poke around on there...... they have a whole explaination of what exactly they do, go to products and look at the TEC3 unit...(tec1 and tec2 are the older and easier to tune in my opinion versions) and the direct fire modules..... the direct firing units are what eleminates the distributor....
drbenne
May 25, 2009 06:26 AM
AnclyT
Sep 5, 2007 12:07 PM
dominate9
Dec 22, 2003 08:51 PM
mister2racer
Aug 1, 2003 06:23 AM
