Tons of CEL codes!!!! Arrrghhhhhhhh!!!!!!!!!!
Old Mar 11, 2008 | 04:31 PM
Blown383's Avatar
Default Tons of CEL codes!!!! Arrrghhhhhhhh!!!!!!!!!!
My 96' EX-V6 with 183,000 has tons of problems. Its been idling badly lately so I swapped out the plugs, cap, rotor, and the wires were replaced less than a year ago. But that didn't help.
Now the car will not idle and won't stay running unless I keep my foot in the gas...however that causes a slight popping sound...which I would assume is a cylinder misfiring. The CEL trouble codes come out to be:
P1300
Random/Multiple Cylinder Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
So I cleaned out the inlet air control valve (IAC), checked the coil, and the ICM (Ignition control module), and still no luck. The cap was installed correctly along with all of the wires. What would cause all 6 cylinders to misfire?
I haven't check fuel pressure yet however when I turn the key to the ON position I hear the fuel pump buzz in the back.
So what gives?!?! :thumbdn:
-B
Old Mar 12, 2008 | 12:37 AM
p10hlm's Avatar
Default Re: Tons of CEL codes!!!! Arrrghhhhhhhh!!!!!!!!!! (Blown383)
sounds like your timing/firing order is off.
i hope you used all oem parts and nothing aftermarket
Old Mar 12, 2008 | 09:54 PM
aasaa666's Avatar
try valve adjustment, with this many miles I would believe that can be one of the problems.
Old Mar 12, 2008 | 10:20 PM
3zFree's Avatar
You can guess all you want, but if you want to know for sure where to start looking get your car gas analyzed. If you want take it to a shop and ask them to hook up a gas analyzer (while car is under operating temperatures) and write down readings at both idle and 2,500 RPM. Bring back results here and we'll tell you if you're dealing with a electrical/mechanical/rich/lean misfire and tell you what to check.
EAST10DECALS
Acura TL, RL & ZDX
Jun 8, 2017 07:06 PM
Uljima
Aug 27, 2015 01:55 PM
ohmygodvtec
Apr 15, 2008 05:56 AM
01celica_gts
Jul 16, 2007 06:22 AM
