messing with stock suspension springs
Old Aug 26, 2008 | 04:04 PM
kingh90's Avatar
Default messing with stock suspension springs
well i went to a shop to get my 2000 Honda prelude lowered and he said that he charges $500 thats including lifetime warranty on springs.
but he said that he can collapse my stock springs and lower it for $50. is it bad to mess with the stock springs especially collapsing them??
Old Aug 26, 2008 | 05:00 PM
prion's Avatar
Default Re: messing with stock suspension springs (kingh90)
You would be asking for trouble by collapsing them. If he uses an installable spring compressor your ride will suffer, you will bottom out easy, and they might clank or fall off. If he heat treats your springs to permanently compress them or cuts off a bit your handling will be much worse and could even be dangerous to you.
Lower it with new springs and get a wheel alignment.
Old Aug 26, 2008 | 07:29 PM
timkh22a1's Avatar
Default Re: messing with stock suspension springs (prion)
new springs all day you can get a set for pretty cheap id suggest neuspeed and if you do the work yourself itll be way cheaper than 500$
Old Aug 26, 2008 | 07:43 PM
EFz6er's Avatar
Default Re: messing with stock suspension springs (timkh22a1)
lowering springs are cheap....but will probably ruin your stock struts/shocks and be super bouncy
Be smart and save up for a decent spring/shock or coilover set up. Basically any spring set is under 200 and a set of good shocks like koni yellows or kyb agx for about 400
so for about 600 unistalled you will have a really nice suspension set up that you will never really have to mess with again.
What ever you do dont let that mechanic cut/modify your stock spring!
Old Aug 26, 2008 | 07:44 PM
vinuneuro's Avatar
I'd run away from any shop that wants to cut/collapse springs.
Old Aug 26, 2008 | 08:07 PM
Kronn 98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingh90 &raquo;</TD></TR><TR><TD CLASS="quote">well i went to a shop to get my 2000 Honda prelude lowered and he said that he charges $500 thats including lifetime warranty on springs.
but he said that he can collapse my stock springs and lower it for $50. is it bad to mess with the stock springs especially collapsing them?? </TD></TR></TABLE>
yes, bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">I'd run away from any shop that wants to cut/collapse springs.</TD></TR></TABLE>
what he said
Old Aug 26, 2008 | 08:58 PM
Hawkze_2.3's Avatar
I wouldn't let anyone do suspension work on my car. One nut gets looked over and you could have a major problem on your hands, I like to double check everything myself and see what's going on down there.
Old Aug 26, 2008 | 09:13 PM
vinuneuro's Avatar
Default Re: messing with stock suspension springs (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't let anyone do suspension work on my car. One nut gets looked over and you could have a major problem on your hands, I like to double check everything myself and see what's going on down there.</TD></TR></TABLE>
I think that goes for any work that needs to be done. You know the quality of work when you do it yourself.
Old Aug 26, 2008 | 09:16 PM
Kronn 98SH's Avatar
Default Re: messing with stock suspension springs (vinuneuro)
agreed, however, I have heard that playing with your under-carriage too long can make you go blind.
Old Aug 26, 2008 | 10:52 PM
kingh90's Avatar
Default Re: messing with stock suspension springs (Kronn 98SH)
alright i probably wont go back to that shop anytime soon then.
Modified by kingh90 at 4:38 PM 8/27/2008
Old Aug 26, 2008 | 11:04 PM
vinuneuro's Avatar
H&R Sport's are your best bet. Make sure to replace the shocks if you lower the car.
Old Aug 27, 2008 | 06:19 AM
ethereal2pt2's Avatar
cutting springs is a big no no. that's just asking for trouble. just cough up an extra bill on top of that and get lowering springs.
admess188
Nov 25, 2008 01:22 PM
power11
Suspension & Brakes
17
Jun 11, 2007 02:25 PM
vermilion
Suspension & Brakes
Aug 1, 2006 01:14 AM
Confucius37
Dec 29, 2004 10:21 PM
Mleach
Jun 30, 2004 12:17 PM
