M2U4
Old Aug 1, 2007 | 08:00 PM
TylerC161's Avatar
Default M2U4
How hard is it to acquire this transmission and would it go into a 4th gen h22a? It seems like the best to get because of its gearing.
Unless theres a better transmission that will work for maximum NA 1/4 mile times that I dont know about
Old Aug 1, 2007 | 08:46 PM
MLBZ521's Avatar
Default Re: M2U4 (TylerC161)
The M2U4 has no where near the "Best Gearing" for an NA Application. Not to mention it's a 5thGen SH/Type-S ATTS Transmission. So you can't use it anyways..
Old Aug 1, 2007 | 08:47 PM
mgags7's Avatar
the m2f4 is the "best" geared trans out of the factory:
m2u4 is an atts trans btw
you can get the same gear ratios with an m2y4 or an m2z4 (lsd)
but
M2F4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.266
M2U4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266
the m2f4 is geared higher in every gear except 2nd, and .006 is very little
Old Aug 1, 2007 | 08:49 PM
lude98SH's Avatar
Default Re: (mgags7)
i have an m2u4 that i would sell pm me if you actually need one.
Old Aug 2, 2007 | 01:04 AM
MLBZ521's Avatar
Matt, are you talking USDM Tranny's or any Market Tranny??
If any market, are you saying the M2F4 is better than the Accord Euro-R and Type-R.
M2U4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 ATTS (For Reference Only)
T2W4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.812 - 4.266 LSD
U2Q7 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 LSD
Besides first gear in both and the last in the T2W4.. Second and Third are higher, and fourth is the same..
Old Aug 2, 2007 | 03:00 PM
TylerC161's Avatar
Default Re: (MLBZ521)
Okay, well I was wrong then. My mistake.
Currently im using the m2a4, then I thought about getting the m2b4 since it has LSD, but then i started looking at all my other options.
Althought all the comments are kind of confusing me, so is the m2f4 the best or not? Like I said, its going to be a complete NA setup, so wouldnt the t2w4 be better then, since it has lsd and close to slightly better gearing then the m2f4?
Better yet, someone should just post a list of all the tranny's that will bolt right up to a h22a (1992), with their respective gearing. That way I wont be confused on transmissions I cant use
Old Aug 2, 2007 | 03:03 PM
MLBZ521's Avatar
Default Re: (TylerC161)
Here:
https://honda-tech.com/zerothread/1876526
https://honda-tech.com/zerothread?id=758902
Any H/F Series Tranny will bolt up. Besides the S200 F20C.
Old Aug 2, 2007 | 03:08 PM
DCxMagus's Avatar
just a note Euro-R trannys are pretty hard to find without buying the whole swap.
Old Aug 2, 2007 | 03:34 PM
TylerC161's Avatar
Default Re: (DCxMagus)
thats what I started to read about.
So I guess its best to keep an open eye for those, but my best luck is probably just a standard m2b4
Old Aug 2, 2007 | 04:11 PM
Silver Surfer's Avatar
i never understood why someone would pick up a whole new trans (especially a rarer/more expensive one) on a budget build for some minor gearing change.......why not get a final drive?
that would be like buying a new computer because your graphics card is to slow, you know you can get them seperately.
Old Aug 2, 2007 | 04:14 PM
vinuneuro's Avatar
Default Re: (Silver Surfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">i never understood why someone would pick up a whole new trans (especially a rarer/more expensive one) on a budget build for some minor gearing change.......why not get a final drive?
you hit the nail on the head
Old Aug 2, 2007 | 05:07 PM
TylerC161's Avatar
Default Re: (vinuneuro)
Because my CURRENT transmission is going out on me. THATS why I want to know about all these others. Im going to need to replace this transmission regardless, and I wanna do it best when I do, thats all
Old Aug 2, 2007 | 05:40 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">
you hit the nail on the head</TD></TR></TABLE>
indeed.
why not buy an obx lsd, tear it down, tune it up, and throw that in too. no need to waste big money on expensive stock transmissions.
Old Aug 3, 2007 | 10:45 AM
TylerC161's Avatar
It seems some of you are having a hard time understanding i NEED to replace my transmission. This is not just a matter of "I want to be quicker", its a matter of buying a completely new transmission
Old Aug 3, 2007 | 11:10 AM
vinuneuro's Avatar
It'd be cheaper for you to just replace whatever is bad in your current trans, and spend the rest of your money on a fd and/or lsd. Otherwise, you'd be better off just getting an M2B4.
Old Aug 3, 2007 | 01:31 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TylerC161 &raquo;</TD></TR><TR><TD CLASS="quote">It seems some of you are having a hard time understanding i NEED to replace my transmission. This is not just a matter of "I want to be quicker", its a matter of buying a completely new transmission </TD></TR></TABLE>
read my post you taint. Fix yours and spend the money you saved on an lsd or an fd
Old Aug 3, 2007 | 10:17 PM
TylerC161's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
IF I were to fix my transmission, I would need:
New housing, new VSS, new throw out bearing, new syncros, and mayyybe new gears.
Im talking F***ED.
$rebuild$ &lt; $New transmission$
And I want to trip on LSD
Old Aug 3, 2007 | 11:26 PM
MLBZ521's Avatar
lol.... He might have you there Matt..
Also, buying another Transmission is better for some people.. As not everything can have their car down for an extended amount of time when it's their DD.. They need quick swaps.
Old Aug 3, 2007 | 11:50 PM
TylerC161's Avatar
That and I dont have to pay labor for someone to rebuild it. (No way I'd try to rebuild myself).
lsjon
Jul 5, 2008 12:30 PM
Prudz_lude
Dec 7, 2006 09:55 PM
Desperado
Feb 21, 2003 04:45 AM
satan_srv
Jan 15, 2003 12:44 PM
