low revs?
Old Sep 10, 2002 | 06:53 PM
Arch-Angel's Avatar
Default low revs?
A couple of times my H23 has been at idle and just stalled (and yes... it was in neutral!)
It normally idles at about 600-650 RPM (i have an Apex'i RSM)
If there is anyone out there with a H23 what do you guys idle at? Is mine too low? Can the idle revs be raised easily?
Cheers!
Old Sep 10, 2002 | 07:44 PM
Cottonwoodz's Avatar
Default Re: low revs? (Arch-Angel)
Just turn the idle control screw on the throttle body counter clockwise, and that will raise your idle up (should be around 800-900 RPMs, I think)
[Modified by Cottonwoodz, 4:45 AM 9/11/2002]
Old Sep 10, 2002 | 08:05 PM
EH2DX's Avatar
Default Re: low revs? (Cottonwoodz)
but first check for vacuum hose leaks. that can couse the problem you desribed.
Old Sep 10, 2002 | 10:59 PM
Arch-Angel's Avatar
Default Re: low revs? (BB1)
Can anyone else confirm what the revs should be??
When I first start the car, it idles at about 1300-1400, and then after a few mins drops slowly to 600. If I rev the engine, by driving or just giving it some gas, withing that first few mins the revs drops straight down to the 600. Same goes with using the a/c.
Is this normal? Does it coincide with the vaccum hose theory?
Would I be doing any damage to the engine by setting the idle revs to around 1500? Obviously I will chew a little more gas when idling and she would get warmer quicker, but would it affect the engine in any other ways?
Old Sep 11, 2002 | 12:25 AM
H23 Power's Avatar
1400 cold idle
700 warm idle with no accessories on
Old Sep 11, 2002 | 04:41 AM
Arch-Angel's Avatar
Default Re: low revs? (F23 Power)
Thanks!
I want to raise the idle RPM, do you think it is going to be harmfull for the engine?
Civicfanatic_09
17
Jul 16, 2012 12:04 AM
TheOdd001
Jul 7, 2008 07:32 AM
777Lude
Aug 13, 2004 09:08 PM
