Loss of power to everything
Old Sep 18, 2002 | 02:27 PM
mountster27's Avatar
Default Loss of power to everything
SO, when i am driving i begin to lose power to my lights, gauges, stereo, brakes and steering. When i rev the engine power comes back temporarily but, it starts to fade again immediately. I had my battery checked and it was low, but when we put in a new battery it still ran low. They suggest that there is something wrong with the charging system.
I had an idea though, since i just had pulleys installed does anything think it may be related to the tension on the belt to the alternator pulley? I hope it isnt.
Has this happened to anyone else? What did you do?
Old Sep 18, 2002 | 02:43 PM
95vtecgook's Avatar
Default Re: Loss of power to everything (mountster27)
u got a system in their?? if you do i had the same problem with my 4th gen..your alternator is weak as ***** and needs to be charged back up...let ur car idel for a good hour or more..don't run anytyhing....just let it run...if you got a stero, buy a power gap battery thingie...better wires and anything that you gettho riged ur prelude up with...ur mean to your lude if you gettho riged ur stuf... shame, shame on you <U>BAD!!</U>
Old Sep 18, 2002 | 03:01 PM
Cottonwoodz's Avatar
Default Re: Loss of power to everything (95vtec****)
Old Sep 18, 2002 | 04:52 PM
rybred's Avatar
u should look into the mean green alternator...i think it's called...if it is your alt, and your sucking alot of power!
Old Sep 18, 2002 | 06:13 PM
I dont have a system. Nothing is installed wrong or shittily. Tech says it the pulleys underdrive the alternator and drained battery when it does not put out enough power. This should be fixed now.
Old Sep 18, 2002 | 07:30 PM
se93's Avatar
I have the same problem. Killed my battery. I had the battery replaced and when i checked voltage directly from the alternator at idle, 3000/5000/6000 rpm, the alternator output was 12.6 volts. Just ordered a Mechman 175 amp alternator to take care of this problem. I have lots of accessories and an extensive audio system which require tons of power. Now, with 175 amps of power, all should run exceptionally.
Regards,
Mark Perez
Import Performance
787.880.6548
Crossbreeder
Feb 5, 2010 07:36 AM
rgl1288
Nov 9, 2009 07:09 PM
vdawg559
Jan 4, 2008 06:39 PM
sicksiguy
Jan 28, 2007 07:37 PM
mountster27
Sep 18, 2002 03:49 PM
