longer time to start
Old Apr 28, 2006 | 04:39 AM
ludecz's Avatar
Default longer time to start
After I installed B&M fuel reg. and gauge and VAFCII I noticed my H22 takes longer time to start it. When I turn key on fuel pump doesn't work for couple seconds like it should, only when cranking. Vafc works fine ( it just been tuned) and my pressure is 32 psi when running, stays on 0 when key on.
Thanks for any ideas.
Old Apr 28, 2006 | 05:19 AM
The Weather Man's Avatar
The fuel pressure is supposed to be ~40psi correct? Do you have a fourth gen? If so, the fuel pressure is too low.
Also, when you turn on the key, you can't hear it prime?
Old Apr 28, 2006 | 03:56 PM
ludecz's Avatar
Default Re: (The Weather Man)
yeah 4th gen. 40 psi? After I installed fuel gauge only the pressure was 30psi at Idle and 40 at WOT after that I put the regulator on and adjusted to 32Psi. Never had any problems and on dynotuning mixture had to be only leaned out.
And yeah the fuel pump don't prime at all and before it did.
Old Apr 28, 2006 | 03:59 PM
soundbomber's Avatar
Default Re: (ludecz)
main relay always clicks too?
JmurGSR98
May 20, 2012 05:26 PM
skUnK2jdm
Jan 30, 2007 03:55 PM
b16acivicsir
Feb 21, 2004 12:43 PM
BoostedD15B7
Nov 30, 2003 03:40 PM
Malgerus
Aug 16, 2002 01:03 PM
