LED light for vtec?
Old Apr 15, 2007 | 11:56 PM
mikeaitken's Avatar
Default LED light for vtec?
i have a little led that i want to hook up when my vtec kicks in. Does anyone know exactly how to wire it up. do i follow the wires directly to the solenoid? The bulb has a red and blue wire coming out of it. anyone? thanks.
Old Apr 16, 2007 | 05:01 AM
THC07's Avatar
Default Re: LED light for vtec? (mikeaitken)
lol, can i ask why you want to do this
EDITED: i menat Kathode not diode. lol
Modified by THC07 at 7:34 AM 4/16/2007
Old Apr 16, 2007 | 05:21 AM
WhiteBB2's Avatar
Default Re: LED light for vtec? (THC07)
I wanted to do the same thing a while back, but didnt know how to do it.
THC07 can you break your answer down to idiot terms?
Old Apr 16, 2007 | 06:31 AM
THC07's Avatar
Default Re: LED light for vtec? (WhiteBB2)
Hook up the Anode to the vtec, Grn/Yel wire at the soleniod. or at the ecu.
and the Kathode to a ground. you probly will have to use a resistor so the LED dont pop. somthing around 300ohms should work.
that resistor goes on the ground wire.
Old Apr 16, 2007 | 08:06 AM
manbearpig's Avatar
i have a flashing one already wired for 12v off ebay, I had it sitting around so i just hooked it up and I like it...........lol, pretty cheesy but people are like "WTF was that?!" I tell em it means my motor almost blew up ..........lol
Old Apr 16, 2007 | 08:44 AM
mgags7's Avatar
Kathode
...sounds like a bad name
lol
Cathode...anyways...
it doesn't matter which side of the LED you put the resistor on, you just want another element in the circuit so the LED only has its turn on voltage, which is usually around .7V for most ebay LEDs
The smaller the resistor you use the more current will flow through the diode, aka it will be brighter, but you should ask the guy you buy it through how much current it can take before it blows.
You should put it up in the dash in one of the empty bulb slots under the water temp and fuel guages and make a little VTAK sticker so it lights up VTAK.
If I were you I'd use a regular bulb instead of an LED, it would make it simpler, and most bulbs can handle 12V, though I think the stock honda ones use a regulated 5V.
Old Apr 16, 2007 | 09:37 AM
idrivealude's Avatar
what for? and if u do, do u want it to light up as soon as the vtec crossover or throughout the whole thing?
Old Apr 16, 2007 | 09:47 AM
I-4's Avatar
I-4
sweet lol. Can someone supply a picture please...I want to see what it looks like.
Old Apr 16, 2007 | 11:19 AM
manbearpig's Avatar
Default Re: (I-4)
Old Apr 16, 2007 | 01:44 PM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Kathode
lol
ahh, got me. Cathode it is!
Considering its not 1830's and I dont live in Germany. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I-4 &raquo;</TD></TR><TR><TD CLASS="quote">sweet lol. Can someone supply a picture please...I want to see what it looks like.</TD></TR></TABLE>
lol, here you go
http://home.earthlink.net/~civ....html
Old Apr 16, 2007 | 07:46 PM
ilikehonda's Avatar
led light for vtec = ricer
Old Apr 16, 2007 | 08:10 PM
DfwBB6's Avatar
Default Re: (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">led light for vtec = ricer</TD></TR></TABLE>
lol
Old May 13, 2007 | 07:19 AM
I-4's Avatar
I-4
Soo...I was bored yesterday all day and decided to visit The Source by Circuit City (AKA Radio-Shack).
Got myself some 22g wire, a nice 12V LED with a built in clip to hold it self in place for $3.99. And a soldering gun, cuz I don't have one, and I figured what the hell I might aswell buy one.
I'm happy with the install it looks clean and almost factory.
It might be more usefull for the SOHC crowd, because they can't really tell when their v-tec kick in.
None the less, I'm happy with it
Here is a zoomed out view.
This is a close-up.
This is what it looks like at night, it has a constant slight glow, not brighter than any other light on the cluster.
And this is with v-tec at work.
Old May 13, 2007 | 07:22 AM
I-4's Avatar
I-4
Sorry, don't know why that 3rd picture is so big.
Old May 13, 2007 | 09:07 AM
IIVIIoOkY's Avatar
Default Re: (I-4)
your gas is low sir
Old May 13, 2007 | 09:26 AM
ficusprelude's Avatar
There is a whole write up on either preludepower or prelude online, i belive it was on a civic, ill try and post it up in a bit.
BTW I - 4 I think your gauge bezels look amazing
Old May 13, 2007 | 09:52 AM
mgags7's Avatar
That writeup is retarded, you could just wire into it at the ecu, there is no point in running a wire all the way from the solenoid.
Old May 13, 2007 | 10:20 AM
preludeMOM's Avatar
Friend of mine does custome guages with a vtec light, ran straight from hondata i believe.
Old May 13, 2007 | 03:19 PM
I-4's Avatar
I-4
Default Re: (ficusprelude)
Thank you sir. This is the site I got the DIY from. http://www.ntpog.org/mods/index.shtml
And this is the bezels write up. http://www.ntpog.org/mods/fift...shtml
Old May 13, 2007 | 03:36 PM
jdizzle!
Guest
Posts: n/a
ghey
krysted9354
Nov 20, 2008 11:33 AM
Jizzmaster Zero
Sep 29, 2005 03:43 PM
00supercivic
Nov 13, 2004 09:47 PM
WhiteGSR95
Jul 17, 2004 05:56 PM
quik2kSi
Jun 24, 2002 01:38 PM
