knock sensor and MSD 6 BTM
Old Apr 15, 2004 | 01:33 AM
94svtec's Avatar
Default knock sensor and MSD 6 BTM
If the 6BTM retards timing under boost. And if I am correct the Knock sensor retards timing as it "hears" detonation and retards timing also. Are the two working against each other? I have a 1994 Prelude H23A VTEC with JE 9:1 pistons, Eagle rods, and the block is sleeved. I have not purchased standalone engine management yet or my upgraded injectors. I usually run 5lbs on low boost and switch to 10lbs. Sorry to get off track but do I leave the knock sensor or just disconnect and use the 6BTM? Please advise... thanks.
Old Apr 26, 2004 | 05:48 PM
mademan2723's Avatar
Default Re: knock sensor and MSD 6 BTM (94svtec)
I would like to know also , anyone?
Old Jun 1, 2005 | 02:16 PM
JDM H22's Avatar
Sorry to bring this back up, BUT, it is a good question and I would like to know
Old Jun 3, 2005 | 10:52 AM
JDM H22's Avatar
Default Re: knock sensor and MSD 6 BTM (JDM H22)
No one?
Old Jun 4, 2005 | 10:53 AM
JDM H22's Avatar
If you could just disconnect the knock sensor, that would be great, however you will be in limp mode and get shitty preset timming maps.
Old Apr 20, 2006 | 06:50 PM
JDM H22's Avatar
wow no one can answer this question huh?
civicgsr499
14
Nov 13, 2008 06:28 PM
AzNsTyLe361
Aug 23, 2007 06:46 PM
1320king
Aug 2, 2007 11:24 AM
untitledsn41
Jul 30, 2004 04:48 AM
MrCrx
Oct 31, 2003 03:18 AM
