JDM Intersection\Cornering Lights, install ?????
Old Jan 4, 2009 | 06:41 AM
Windwalker's Avatar
Icon2 JDM Intersection\Cornering Lights, install ?????
Not sure if intersection light is correct. I've seen them called cornering\side fog lights
these are lights that would replace the side\front turn signals and stay on as you're making a turn.
here's a set that sold on that auction site
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
I've got a lead on them locally and wondering if plug and play is really true
any pointers?
Old Jan 4, 2009 | 10:27 AM
JDMLude850's Avatar
Default Re: JDM Intersection\Cornering Lights, install ?????
i would imagine it being plug & play
Old Jun 9, 2010 | 11:01 PM
cfran55's Avatar
how do you install these? do i need to remove the stock harnesses
the harness i have has everything in line but im wondering if i remove the stock one on my car how about the fog and the horn wiring?
Old Jun 10, 2010 | 01:08 AM
|eG|BB4's Avatar
I would not imagine it being plug and play, because our factory set-up does not stay on while our turn signal is on. I do believe it can be done without the harness needed for it as well.
Old Jun 10, 2010 | 05:41 AM
cfran55's Avatar
sorry i have the harness that includes everything for the turn signals/sidemarker and the cornering light i just dont know how to hook it up
Old Jun 10, 2010 | 06:16 AM
Kane666's Avatar
shimee on prelude power has a writeup on putting these in
Old Jun 10, 2010 | 06:47 AM
cfran55's Avatar
his was for a 5th gen im looking for one for a 4th gen
Old Jun 10, 2010 | 10:24 AM
cfran55's Avatar
ok i got this from a seller
You`ll need to find the relay which is behind the left headlight, close to the cruise control actuator (a big round thing with a single wire going to the firewall). You have to disconnect this relay and piggy back the blue fuse in it, then you disconnect the left and right turn signals and piggy back the left and right cornering lights, and last you disconnect the right corner light/which illuminates first when you turn on the lights switch once, and piggy back the two connectors left to it.
Easy enough, it makes sense when you think about it.
Hope that helps!
by piggybacking does he mean splicing?
Old Jun 16, 2010 | 02:09 AM
cfran55's Avatar
any idea i want to get these in today
goldenmustache
May 2, 2009 10:47 PM
tweek_boii
10
Mar 17, 2009 09:01 PM
00jdmsi
Jan 28, 2007 08:29 AM
KMk51188
Feb 13, 2006 12:11 AM
ewn1603
Dec 1, 2004 11:59 AM
