Jdm H22a Coolant Temp Sensor HELP!!!
Old Jun 29, 2008 | 07:22 AM
G.C's Avatar
G.C
Default Jdm H22a Coolant Temp Sensor HELP!!!
im using my h23 wiring harness on the jdm h22a. and came across a lil problem. i noticed there was one plug not connected to the sensor. and noticed the Coolant Temp Sensor Did not come with the Jdm h22a. Should i change the whole thing with the sensor already on it or just leave it. will i need that sensor? since it didnt come with the engine.
Old Jun 29, 2008 | 07:34 AM
no1knows908's Avatar
Default Re: Jdm H22a Coolant Temp Sensor HELP!!! (G.C)
Well that is for fan switch B, since the fan controller is on the chassis I would run the second switch.
Old Jun 29, 2008 | 08:08 AM
oranginal's Avatar
you don't need the sensor, all is does it keep the fans running while the car is off if it detects the coolant is hot at that point.
there is another sensor that monitors the temp while the car is on so this one works when the car is off.
you could swap the pieces between the engines but it might start to leak and give you problems.
I left mine off for now
Old Jul 3, 2008 | 02:11 PM
rayrayh22a's Avatar
you don't need that extra sensor (ECT switch B aka fan switch that turns on the fan when cooling fluid is too hot), but if your going to run buddy club racing fan switch then you will need the accord one that has that switch b on it because the buddy club sensor won't bolt on to the one on the back(in thermostat housing).
Old Jul 4, 2008 | 01:13 AM
High Reved Racing's Avatar
Default Re: Jdm H22a Coolant Temp Sensor HELP!!! (rayrayh22a)
not shore about the sensor in front but the one behind it with the green plug you need, you won't get vtec without it
Old Jul 4, 2008 | 06:23 AM
rayrayh22a's Avatar
Default Re: Jdm H22a Coolant Temp Sensor HELP!!! (High Reved Racing)
there is two green plugs behind one is on the thermostat housing the other is either vtec pressure switch or solenoid these you don't touch. i was talking about the one on the thermostat housing.
Old Feb 12, 2009 | 11:42 PM
smackdown's Avatar
i have the same issue , now im car overheats somtimes im thinkin this has somthing to do with it.
Old Feb 13, 2009 | 05:30 AM
oranginal's Avatar
this sensor (fan switch B) (the sensor that goes to the piece where the upper rad hose connects to the head) only turns the fans on when the car is off. so if you're overheating when the car is on you have other problems.
the green sensor connected to the thermostat (fan switch a) turns the fans on when the car is on, so if the fans aren't coming on when the car is on and heated up check that sensor.
Also check the lower rad hose to make sure it is warming up (after the car has warmed up obviously) to make sure your thermostat isn't stuck.
Old Feb 13, 2009 | 08:35 AM
92bb2's Avatar
I have a sensor on the JDM thermostat housing that's green. On my H23 harness, will I have a plug that connects to that????? I swapped the coolant necks on the front of the head for "fan switch B" so that should be good.
In short, I need the fan to turn on when its 100* out and I'm sitting in traffic.
Old Feb 13, 2009 | 01:01 PM
smackdown's Avatar
anyone know what sensors are these ? im lookin for the temperature sensor
Old Feb 14, 2009 | 07:33 AM
92bb2's Avatar
the white connector is the coolant temp sensor for the ecu I think. The one next to it is for the temp gauge. The coolant neck on the front side of the motor is supposed to have "fan switch B" and then the other fan switch is in the thermostat housing.
Old Feb 16, 2009 | 02:53 AM
smackdown's Avatar
thanks for the info.
Old May 6, 2020 | 04:02 PM
thatguyjade's Avatar
What color wires go to all the coolant sensors? I’m lost and can’t find the sensor that goes to the coolant neck
nogodracer23
Nov 20, 2013 12:10 PM
makeustruggle
May 15, 2009 01:34 PM
Simmerman
12
Sep 18, 2007 07:05 PM
DropSquadCivic
Aug 25, 2003 03:57 PM
