inside distributor the plastic shield, is it necessary?
Old Jun 4, 2007 | 07:58 PM
mattsnooz's Avatar
Default inside distributor the plastic shield, is it necessary?
that god damn plastic shield inside my distributor (divides electronics from rotor and cap) never fit properly and made a plastic scraping on plastic noise like the rotor was hitting the inside plastic cover. i pulled it out, sounds gone but im sure it was there to protect wires from arcing and maybe high radiant heat??
anyways, i pulled the ***'n thing out and just want to make sure its not going to cause any problems. Please any thoughts??
Old Jun 4, 2007 | 08:07 PM
ericdachampion86's Avatar
Default Re: inside distributor the plastic shield, is it necessary? (mattsnooz)
yea its main purpose is to keep the spark from arcing to the casing of the dist. My 97 h22a doesn't have it on and i haven't had any problems yet.
Old Jun 4, 2007 | 08:08 PM
mattsnooz's Avatar
Default Re: inside distributor the plastic shield, is it necessary? (ericdachampion86)
why isn't yours on? same problem?
Old Jun 5, 2007 | 07:16 AM
mattsnooz's Avatar
any other opinions? is that internal shield absolutely necessary? if its out should i add insulation or insulate anything? wires/chip maybe?
anybody else have that problem with distributor? that shield never fit right like i said. it sat loosly inside the distributor cap
Old Jun 5, 2007 | 07:30 AM
TheWalrus's Avatar
no you dont need that shield. i think its there in case a wire falls off and arcs...which can kill a coil. honda over thinks everything
Old Jun 5, 2007 | 07:57 AM
mattsnooz's Avatar
Default Re: (TheWalrus)
okay, thanks guys. your two votes and my vote are good enough for me.
At least it doesn't sound like a garberator with tin can stuck in it, like before
i thought the gear inside on the shaft was stripped, or stripping(or how ever the distributor spins)
theEFkid
Apr 9, 2012 05:43 PM
BoombasticSloth
Jun 21, 2008 03:39 PM
92 CIVIC HATCH VX
Apr 12, 2006 09:58 AM
monalisa overdrive
Apr 19, 2004 09:07 PM
