info on converting jdm OBDII engine to OBDI
Old Jan 24, 2002 | 04:23 PM
4bidden's Avatar
Default info on converting jdm OBDII engine to OBDI
alright guys...i need help quick.
what all needs changed to hook up a jdm OBDII motor? the distributor, injectors, ecu and what else?
also...do any of you have info on the new H23A VTEC motor from the new accord type-r's? how are they getting 2.3L out of it? its pretty much a h22 but somehow theyre getting 2.3L out of it. im guessing just a diff crank. should the head accept the same parts as a h22? i mean would i be able to buy H22 valvetrain parts like cams etc and it would fit?
thanks a lot for any info you have!
Old Jan 24, 2002 | 07:00 PM
aklucsarits's Avatar
New User
Default Re: info on converting jdm OBDII engine to OBDI (4bidden)
Where are you putting this OBD2 motor?
Assuming it is to go into an OBD1 Prelude...
You need some of the parts you mentioned - the 97+ injectors and ECU. Plus, you need a secondary O2 sensor (or some way to trick the ECU into seeing one) and O2 sensor bung behind the cat to plug it into.
As far as the distributor goes, you can use the 92-96 Prelude distributor from an H23 or an H22a. This will save you the hassle of rewiring the distributor harness. If you need to use an 97+ Prelude distributor, you will also need to rewire the OBD1 distributor harness because at least one sensor that was in the distributor on 92-96 Preludes are now on the crank on the 97+ motors...
It's not a 2.3l VTEC. It's a 2.2l H22a in both the Euro-only Accord TypeR and the Japan-only Accord Euro R. Both have essentially the same motor as the JDM S-spec Prelude motor- 2.2l and ~220ps.
Andrew
Old Jan 24, 2002 | 08:12 PM
4bidden's Avatar
Default Re: info on converting jdm OBDII engine to OBDI (aklucsarits)
actually it IS a 2.3L. the "euro accord-r" is still a h22 though. the 2.3L is rated at 227
Old Jan 24, 2002 | 08:21 PM
4bidden's Avatar
also...maybe you misunderstood me. i dont want to hook it up obdII. i want to adapt it to obdI. know what i mean now?
Old Jan 24, 2002 | 10:45 PM
OneThirtyEight's Avatar
an OBD1 ECU and a OBD1-OBD2 Wiring harness
Old Jan 25, 2002 | 05:02 AM
New User
There is no such thing.
Andrew
Old Jan 25, 2002 | 05:08 AM
New User
Default Re: info on converting jdm OBDII engine to OBDI (97blackteg)
It's not that easy. You need more than that on an H22a for an OBD1 swap. The problem is that OBD1 H22a's had peak and hold injectors while the 97+ H22a's have saturated injectors.
The subject of an OBD2->OBD1 swap has been covered at length recently. Try a search.
Andrew
Old Jan 25, 2002 | 06:24 AM
4bidden's Avatar
what are you tryin to tell me that there is no such thing??
Old Jan 26, 2002 | 05:29 AM
DirtyLude's Avatar
All you need is the OBD II -> OBD I adapter harness. If the OBD II engine you are getting has high resistance injectors already, then you will need to wire around the resistor box that you should already have. If the engine you are getting has low resistance injectors than nothing else is needed.
elisha22
Nov 3, 2015 04:06 PM
accordmatt
Aug 29, 2010 07:14 PM
kyleclapp
Nov 21, 2008 04:20 PM
H22LUDE808
Mar 29, 2008 11:24 PM
3litre190
Jul 25, 2007 01:47 AM
