is this illegal?
Old Mar 20, 2003 | 09:55 AM
sslude's Avatar
Default is this illegal?
i went to test pipe.com and found this http://www.testpipe.com/htmlsite/pro...&pstring=67,68 is that illegal? and does anyone use it? how is it? does it throw a code or anything? sorry about all the questions. thnks
Old Mar 20, 2003 | 10:14 AM
RAB's Avatar
RAB
Default Re: is this illegal? (sslude)
Its only illegal if you get you car tested for emissions. You'll have to take out the secondary O2 sensor and by doing so you'll get a CEL. I know the Primary O2 sensor helps in control the a/f ratio, but I don't know how important the secondary is to controlling the a/f ratio.
Old Mar 20, 2003 | 10:42 AM
aklucsarits's Avatar
New User
A "test pipe" is Illegal to use on the street in all 50 states, regardless of whether or not they test for emissions in your area. It is against federal law to remove or disable the catalytic convertor on any car regsitered for the street.
Read: http://www.epa.gov/compliance/resour...hsysrepair.pdf
You will also get a CEL due to the secondary O2 sensor being removed.
Andrew
Old Mar 20, 2003 | 11:12 AM
RAB's Avatar
RAB
Default Re: is this illegal? (aklucsarits)
I know its illegal I was just trying to state that you're probably not going to get caught unless you at an SCCA street touring event, or the cop really knows his stuff.
Old Mar 20, 2003 | 01:29 PM
tha Big EZ's Avatar
Default Re: is this illegal? (RAB)
do some searching and find ( which is not very hard!) an OBDII --> OBDI. That completely takes the second O2 sensor ie: the one thats gonna throw the code, out! WHile your at it get a chipped ecu! with the II-->I harness itll fix it where what you want will work!
Old Mar 20, 2003 | 02:15 PM
MugenPoweredLude's Avatar
Default Re: is this illegal? (likwid)
while youre at it get a HONDATA!
Old Mar 20, 2003 | 03:07 PM
mt23vtecbb2's Avatar
Default Re: is this illegal? (MugenPoweredLude)
things are only illegal if you get cought!
Old Mar 20, 2003 | 08:14 PM
vtecfiendsh's Avatar
Default Re: is this illegal? (mt23vtecbb2)
would it be possible to drill and tap a test pipe for a o2 sensor? and keep the second o2 sensor would this trip the CEL ?
Old Mar 21, 2003 | 04:04 AM
im sabah's Avatar
Default Re: is this illegal? (vtecfiendsh)
you can do that but it wont do anything. the second o2 sensor checks to see if the cat is doing its job. since you removed the cat obviously the gases will not be "clean" enough and will trip your second o2 sensor.
Old Mar 21, 2003 | 01:14 PM
Default Re: is this illegal? (im sabah)
thats what i was guessing woudl happen
Old Mar 21, 2003 | 01:22 PM
YumVTEC's Avatar
be careful about removing your cat, it's like a $10,000 federal fine if you are caught and if the person that catches you feels like citing you.
j.bro
Honda Civic (2001 - 2005)
Mar 31, 2011 11:36 AM
mistawho
Dec 20, 2005 09:01 AM
Chris_Bye
May 1, 2005 07:56 AM
RISING SUN RACING
Jan 17, 2003 09:53 AM
amrintegra
Nov 5, 2001 07:21 AM
