Which ignition coil fits the h22?
Old 03-14-2010, 08:18 AM
dvp95's Avatar
Default Which ignition coil fits the h22?
Quick question for you guys. I have a 96 accord and swapped in a 98 JDM h22a. The coil is now bad. I want to simply swap in a new coil but the JDM version is internal and the USDM version is external. Which can I buy for a direct swap?
https://honda-tech.com/forums/showth...=ignition+coil
That thread mentioned the 94/95 integra. Is this correct? And will this work for all year h22as since the link doesnt specify what year he has? Thanks.
Old 03-14-2010, 09:00 AM
ilikehonda's Avatar
Default Re: Which ignition coil fits the h22?
check out the coil from a 98 civic ex. i know that the dist cap works on the h22. so the coil may work too it is also internal.
Old 03-14-2010, 10:37 AM
nsxter's Avatar
any obd1 or obd2 coil will work
Old 03-14-2010, 10:47 AM
dvp95's Avatar
From which vehicle? Thanks for the replies.
Old 03-14-2010, 01:33 PM
nsxter's Avatar
civic, prelude, integra, accord any model obd1 or obd2 do you not know what obd1 or obd2 is
Old 03-14-2010, 07:29 PM
dvp95's Avatar
haha yes I know what obd1 and 2 are. I was wondering which car is interchangeable. I didnt know any honda would work cause I dont know what all the coils look like. At any rate I used the integra one. It was about 1mm too thick to fit in the slot but I made it work.
DigitalPunk
07-27-2013 12:53 PM
mortificationrock
04-18-2008 06:18 PM
Quick Reply: Which ignition coil fits the h22?
