Idle probs
Old Apr 4, 2011 | 08:39 AM
jdm_prelude19's Avatar
Default Idle probs
Ok so my Prelude's idle will hang around 600rpm after it is warmed up, and it feels really low, sometimes it will bounce back and forth between 6 and 9. also once in a while, when its low and i try to go it will stall. I checked the battery and the alternator, their both up to voltage specs, and i removed my subs a while ago..what else could be causing this?
Old Apr 4, 2011 | 09:02 AM
carnot's Avatar
Default Re: Idle probs
I would go through the idle adjustment procedure:
1. warm up car completely.
2. while engine is running, unplug electrical connector for the IACV
3. set idle to ~700rpm by turning the idle screw on the throttle body
4. turn off engine, plug IACV back in, reset ECU
Could be other things such as old ignition components; is the CEL on?
Old Apr 4, 2011 | 05:58 PM
BlackCatt's Avatar
Check out this thread, its great for solving idle issues,
Mgags7 did a great job with this write-up:
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
honcrf150
Jan 1, 2013 04:03 PM
jah.tien
Jul 14, 2010 10:37 AM
whitediamond642
Apr 10, 2007 04:37 AM
Brian_92GSR
May 31, 2004 03:57 PM
killa_lude
Aug 16, 2003 08:33 AM
