Hub removal.....HELP!
Old Jun 5, 2002 | 11:13 AM
apexii's Avatar
Default Hub removal.....HELP!
How the hell do I remove the hub from my preludes suspension? I have the rotor and caliper off, but I can't figure out how to get the damm hub off. I need to replace my wheel studs.
The hub seems to be pressed on, but I don't want to damage the wheel bearing in the removal process. The Helm is sort of vague, says to use 'special tool' for removal and a press. Do I have to remove the whole knuckle/hub assembly and take to a press? Can I get away with a gear puller instead?
This is also posted in Tech. Thanks.
Old Jun 5, 2002 | 02:36 PM
LoudLude's Avatar
Default Re: Hub removal.....HELP! (apexii)
front or rear?
Old Jun 5, 2002 | 02:49 PM
apexii's Avatar
Default Re: Hub removal.....HELP! (LoudLude)
Front.
Old Jun 6, 2002 | 07:56 AM
apexii's Avatar
upyougo!
ewoo
Feb 24, 2009 04:23 PM
kornerk12
May 21, 2007 01:41 PM
mr2turbo
Mar 1, 2004 09:19 AM
apexii
Jun 11, 2002 06:18 PM
InfamousRS
Feb 11, 2002 09:36 PM
