How does the Main Relay Work
Old May 9, 2009 | 04:15 PM
The AW Alchemist's Avatar
Default How does the Main Relay Work
Now I know that there are 7 wires for the main relay.
1 wire is a constant 12 v source
1 wire is a constant negative source
1 Goes to the fuel pump
1 goes to the ecu
1 goes to the ecu
1 goes to the ignition
1 goes to the starter
Now my question here is how does the main relay tell the fuel pump to work.
Does it always keep it on. Like say, you connect the power wire to a constant power source and not wire it to the main relay. That turns the fuel pump on constantly. I can hear a humming and I have fuel pressure, but it keeps it on all the time.
Is this normal, or not the way the main relay works.
Old May 10, 2009 | 08:14 AM
withoutlimitslude's Avatar
Default Re: How does the Main Relay Work
all i know about the main relay that if that is going out your gonna be very frustrated trying to get around in your car...mine was going out and it would start when it wanted to it sucked!!!
Old May 11, 2009 | 10:53 AM
sean1121's Avatar
Not normal, the fuel pump is switched with the ignition switch.
Old May 11, 2009 | 06:11 PM
I dont understand what you are telling me here.
You say it works with the ignition switch. That means once you turn the car on, the fuel pump activates, and only deactivates when the car is off.
Old May 11, 2009 | 06:35 PM
92hondalude's Avatar
it should prime once you get into acc. then you start the car its always on till your turn the car off..
milanoitr
54
Feb 28, 2012 09:07 PM
civic89si666
20
Dec 21, 2009 10:25 PM
boosteddohczc
10
Jun 11, 2009 09:57 PM
95turboeg
Jul 7, 2006 11:38 AM
X2BOARD
Apr 18, 2003 08:56 AM
