Minimum voltage to active a Relay ?
Old Apr 17, 2003 | 11:23 AM
X2BOARD's Avatar
Default Minimum voltage to active a Relay ?
I plan on installing a radio shack SPDT or DPDT Bosche relay on a possible low voltage source.
What is the minimum voltage/power necessary to activate a typical relay ?
I will be using it to activate and de activate the fuel pump...
X2
Old Apr 17, 2003 | 11:40 AM
kb58's Avatar
Banned
Default Re: Minimum voltage to active a Relay ? (X2BOARD)
Tough to say. Hook up the relay in question to a variable power supply, and increase the voltage until you hear it click. There you go.
The catch is, relays are heat sensitive. The hotter the relay is, the hotter the copper wire is, which increases its resistance, which means you need more voltage to activate it...
Old Apr 17, 2003 | 08:23 PM
hatchy's Avatar
dude, if you find out, please let me know!!
Old Apr 17, 2003 | 09:10 PM
ScottEK's Avatar
Default Re: Minimum voltage to active a Relay ? (hatchy)
Why dont you just got a heavy duty DC switch and use smaller gauge wire than the stock power line running to the fuel pump?
Old Apr 17, 2003 | 09:46 PM
Padawan's Avatar
Darth ModerVader
Not sure if this is helpful or not:
30 Amp Automotive Relay
DPDT 10 Amp 12V
Old Apr 17, 2003 | 11:15 PM
sparkz's Avatar
Default Re: Minimum voltage to active a Relay ? (Padawan)
most automotive relays require at the bare minimum of at least 10v to operate and even at 10v, it could be sketchy. anything below that might work, but prolonged use would cause it to "pulse"
Old Apr 18, 2003 | 08:56 AM
X2BOARD's Avatar
Default Re: Minimum voltage to active a Relay ? (sparkz)
This is why I need it.
I am putting in a relay for a fuel pump kill switch and of course don't want to use an inline switch. I want a relay'd switch for obvious reasons, but want to ensure the relay will stay engaged while powered and not shut off... I used to use a relay for my 12v in car neon w/o a hitch (flame if you want ) But want to make sure, cuz don't want the fuel pump to die on me.
Anyone else done a relay to kill the fuel pump ? Any probs w/ it ?
X2
no_regrets
Apr 21, 2015 08:23 PM
redline1320
Apr 27, 2010 06:55 PM
The AW Alchemist
May 11, 2009 06:35 PM
northemt88
19
Mar 4, 2009 09:15 AM
tnaracetuning
Sep 1, 2008 04:27 PM
