Hondata problems....
Old May 19, 2003 | 06:31 AM
96SR-V's Avatar
Default Hondata problems....
I have a feeling I'm not the only one... these things are assembled by a bunch of trained monkeys. I bought a stage three last year and controls like my full throttle shifting and launch control are not working. Anyone else have a stage three? How do u set these? Any input or general frustrations w hondata are welcome....
Old May 19, 2003 | 06:51 AM
BoostedH23a1's Avatar
Default Re: Hondata problems.... (96SR-V)
u sure u got it installed correctly.. i konw for full throttle shift u have to use their switch..
Old May 19, 2003 | 11:08 AM
Firedrake's Avatar
On my s200 I couldn't get the rpm levels to set using the button, I had to set them in hondalogger. I called Hondata about the problem and they said just send the unit in to them and they'll fix it. They're pretty good about that kind of stuff, I'd just call them and send in your unit
Brian
Old May 20, 2003 | 02:41 PM
Default Re: Hondata problems.... (Firedrake)
i can set my launch fine with the button but i cant sent the shft light.. i do that hondalogger.
Old May 20, 2003 | 08:33 PM
areyouasian's Avatar
i heard the stage 2/3/4 have lots of problems. i have alot of problems with my stage 2. my car just cuts off at times when im sitting at red lights in neutral. also sometimes while im driving it will cut off also and everytime after i pump gas and i start the car back up it idles very low, about 300 or so until i drive around for about 2 mins then it returns to normal. i talked to several other people and they had the same problems so they stopped using the hondata. i dont know if this is with all the stage 2/3/4's or not but i heard the s200 system was a lot better and this problem was fixed on it.
turboteg185
Oct 28, 2007 10:33 AM
1Bar GSR
Dec 28, 2004 12:24 AM
Cole D
Jan 26, 2004 01:53 PM
Pro-Lude
Oct 4, 2001 02:55 AM
mr.sleeper
Jun 25, 2001 08:37 AM
