Help, headlights stopped working
Old May 12, 2009 | 06:49 PM
h22lude317's Avatar
Default Help, headlights stopped working
my headlights were working fine the night before it happened
the bulbs are fine
Checked every fuse
swapped out relays
my connector looks burnt i could only get one light bulb out but i bet the other one is like that
Im just wondering if there is any way to fix this, i really dont wanna go to the dealership
p.s. my high beams work
i have a 92 base s
Old May 12, 2009 | 07:05 PM
Kronn 98SH's Avatar
Default Re: Help, headlights stopped working
More info please. Do your dash/tail/brake/dome lights work? How do you know the bulbs are fine? Have you tried plugging the highbeam into the lowbeam socket?
Old May 12, 2009 | 07:07 PM
h23prelude's Avatar
get a test light and start testing for power along the circuit. From the info you supplied it's probably a short/open wire between the power side of the relay and the bulbs.
also check for headlight switch operation.
Old May 12, 2009 | 08:09 PM
h22lude317's Avatar
my dash/tail/brake and dome lights work
the bulbs do not look burnt or anything, its still in one piece
my corners do not work.
i haven't tried but i will.
when i turn on switch for headlights passenger side corner light turns on
Old May 12, 2009 | 08:10 PM
h22lude317's Avatar
will do
Old May 12, 2009 | 08:49 PM
Kronn 98SH's Avatar
So to clarify, one of your sidemarkers works and the other doesn't? Did you notice this at the same time as the headlights?
FYI, headlight bulbs can be bad without any visual signs.
Old May 13, 2009 | 04:29 AM
h22lude317's Avatar
one of the sidemarkers turns on but doesnt blink it turns on with the low beam switch
and i tried a different bulb out of another prelude known as working
Old May 13, 2009 | 04:36 PM
h22lude317's Avatar
bump, anyone good with wiring?
EGhachiback
Nov 18, 2013 02:42 AM
JDMin206
Lighting
Jan 10, 2012 05:28 PM
mortificationrock
11
Dec 1, 2009 12:39 PM
rossockr
Aug 14, 2003 05:59 PM
FnkyChnkyMnky
Jun 20, 2002 02:21 PM
