.help fast fast please???
Old Dec 3, 2002 | 06:43 PM
LuderX's Avatar
Default .help fast fast please???
i was driving dis morning and my car's engine check light turned on. i was lyk no. then my d4 light started to blink. if you have not notice so far i got a SS, but my tranny was fixed by honda at 39,000 miles. and now i got 49,875 don't ask i was the second owner. the first owner was my uncles. well back to the story, i went home and then i check the oil sorry i'm a noobie. the oil was black and smelled lyk gas mixed wit oil but smelled more lyk gas. i mean the car drove fine all the way home. no diffrent at all. When i got home i poured more oil in i use mobile1 synthic. I heard it was really good to use so i use it, but do you guy's think its because i have a intake and no exhuast or header that makes the oil that black. even before i was suppose to change my oil it was already low and it was really dirty. thank you guy'z for all the help need quick help. also i wanted to know if the engine check light is on how do i turn it off myself i heard to reset the ecu. i was thinking if i pulled the fuse for it would that work. also if you can could you tell me how to reset the ecu. thank you guy'z i was so scared this morning i was lyk its my second car and i never had that happen to me before.
Old Dec 3, 2002 | 07:04 PM
93 VTEC's Avatar
Default Re: .help fast fast please??? (LuderX)
If your oil wasn't low you shouldn't have added any.
If your CEL and D4 light are blinking it is most likely a tranny problem. Don't just reset the light, take it to your dealer to have it looked at.
Old Dec 3, 2002 | 07:08 PM
LuderX's Avatar
Default Re: .help fast fast please??? (93VTEC)
no the oil was low, and i can't bring it to the dealer i have to put back the stock intake first. also after i had turned off the car, and turned it back on. the d4 stop blinking but the cel was still on. does that mean it was not the tranny? nothing went wrong on the car, i could still shift through all 4 gears and they would shift fine. no lag no hard shift nothing at all. but when i got home i checked the oil an it was dark. lyk really dark. i was just wonding if it was that? also if it was the oil after i change it i still have to reset the ecu to get the light off right?
Old Dec 3, 2002 | 07:19 PM
sharkcohen's Avatar
If the CEL comes on AND the D4 blinks, then the TCM is reporting that a transmission code has been thrown. DO NOT RESET. The whole point of the CEL is to tell you something. It is not merely an annoying light that comes on that has to be made to go away. If you do not have a datalogger or a code scanner, then take your car to a dealer and have the car checked out.
[Modified by sharkcohen, 2:05 AM 12/5/2002]
Old Dec 3, 2002 | 07:22 PM
piotrush's Avatar
What the hell does 'lyk' mean? I've never encountered that word.
LuderX's Avatar
Default Re: .help fast fast please??? (sharkcohen)
ok but should i put back the intake first before i bring it to the dealership, because i'm scared that they might take the warrentie off.
Old Dec 3, 2002 | 07:23 PM
LuderX's Avatar
lyk = like
Old Dec 3, 2002 | 07:40 PM
sharkcohen's Avatar
Do you know how to retrieve the code by jumping the service connector? If you get the code yourself, you can post it up and I or someone else with a Helm manual will be able to tell you what the problem is.
Old Dec 3, 2002 | 07:42 PM
LuderX's Avatar
how do i get the code i can't don't know how.
Old Dec 3, 2002 | 09:53 PM
sharkcohen's Avatar
On the passenger side of the center console, just below the dash there is an access cover. Pull that cover off and you will expose 2 connector plugs. You want the smaller plug with 2 leads. This is the service connector. With the car off, jump the two leads with something metal. A small paper clip works well. Once the service connector is jumped, turn the ignition key to the "on" position (don't start the engine). If you've done everything right up to this point, the CEL should now be blinking. You will see a series of long and short pulses. Long pulses represent a numerical value of 10, short pulses 1. There will be a long pause in between the series of blinks. Add up the long and short pulses, that is the trouble code. Post the code here. If the D4 is blinking when you jump the service connector, count its pulses as well, as it is also reporting a code that is seperate from the engine code. Post it up as well.
Old Dec 4, 2002 | 05:10 AM
LuderX's Avatar
ok i will try it today. just leave the paper clip their and turn on the car, but don't start it i will give you guys the code asap. after i get out of school.
Old Dec 4, 2002 | 08:13 AM
LuderX's Avatar
the check engine light went on blinked 7 times, and the d4 blinked 4 long and 5 short. what does that mean?? thanks and could you guys tell me asap. thank you.
Old Dec 4, 2002 | 08:14 AM
prelude1897's Avatar
If you decide to take it back to the dealership, then put your stock intake back on before going there. Anyways, heres the site to see how to jump your cel.. Go to http://www.hondaprelude.to/main_checkengine.html
Old Dec 4, 2002 | 10:16 AM
sharkcohen's Avatar
I can look up the codes for you when I get home from school in a few hours.
[Modified by sharkcohen, 12:32 AM 12/5/2002]
Old Dec 4, 2002 | 12:52 PM
LuderX's Avatar
thanks you guy'z, also could you tell me the what the code mean's. thank you. i thought it mean running to rich.
Old Dec 4, 2002 | 03:36 PM
sharkcohen's Avatar
Are you sure that it was 4 long and five short for the tranny trouble code? There is no tranny code 45. Your engine trouble code is 7, throttle position sensor: open or short in the throttle position circuit.
Old Dec 4, 2002 | 03:46 PM
LuderX's Avatar
i don't really know,the engine check light it did not blink as fast as the d4 when the d4 was blinking fast. but the d4 blinked 4 long and 5 short. if you don't beleive me i do it again just to make sure?
[Modified by LuderX, 12:49 AM 12/5/2002]
Old Dec 4, 2002 | 03:58 PM
LuderX's Avatar
i just went out side again and the d4 blinked 4 long and 5 short, and the check light blinked 7 times as long as the d4 when it was blinking long.
Old Dec 4, 2002 | 05:01 PM
sharkcohen's Avatar
Ok, the engine code you are throwing is 70, which just means that there is a transmission problem and it is referring you to the tranny code flashed by the D4 light. However, there is no tranny code 45, I don't know what to tell you there.
Old Dec 4, 2002 | 07:00 PM
LuderX's Avatar
thanks for everything guy's we will see what happens. i'm bring the car into honda tom. for the check up. $70 for them just to test it. and then they see if they would pay 4 it. cuz i have a 2001 prelude and they serviced my tranny at 39,000 miles. cuz i heard honda extend the warrentie for trannie to 100,000 now. cuz of all that had happened.
Old Dec 4, 2002 | 07:02 PM
LuderX's Avatar
o yea i reinstalled the intake. it took to long. hurt my back darn it. hahah but its cool at least i know its a tranny problem. could i tell them i brought the car to a place and they ran a test and said its a trannie problem???
sharkcohen's Avatar
Keep us posted, I'm interested in hearing what the problem is.
Old Dec 4, 2002 | 07:03 PM
sharkcohen's Avatar
I wouldn't tell them anything. The codes are there, those are the first things they will check.
Old Dec 4, 2002 | 07:04 PM
LuderX's Avatar
also would honda put a manual trannie now, since i got mine broke twice already. i hate this dam SS thing its so crappy. i don't drive hard on it i don't go past 4000rpm for daily drive and the tranny is messing up on me.
Old Dec 4, 2002 | 07:05 PM
sharkcohen's Avatar
No, they won't do a 5 speed swap for you as a warranty repair.
