help with code 9 and code 22
just installed a hondata with a p28 ecu. i am running on a basemap. i am throwing code 9 and 22. code 9 is a cylinder sensor and code 22 is vtec pressure valve. any help with describing the codes and/or fixing the problems, would help. thanks
09 Cylinder Position sensor = Open or short in CYP sensor circuit, defective CYP sensor.
22 VTEC Oil Pressure Switch =
Open or short in VTEC OPS circuit, defective VTEC pressure switch
There isn't much else to check other than the wiring to the sensors for faults / shorts, other than that it's as matter of replacing defective sensors.
Assuming all the contacts in the ECU are firm and sound.
ach2291
Feb 10, 2013 09:07 AM
