Help Check Engine Light is on !!
I pulled CEL code 22 and 41 on h22a P13 ecu. Code 22 is VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch. Code 41 is Primary Oxygen Sensor - Heater circuit malfunction. What is the best way to troubleshoot these 2 codes? Should i just replace the Vtec Oil pressure switch? or the oil pressure switch? or What should i do ? Please point me in the right direction. I am really poor right now and cant afford to take it to a shop. Thank you very much in advance.
take the vtec solenoid off and clean it. If that doesnt fix the issue, you need to replace the sensor. The sensor may be a part of the solenoid tho so you may have to replace the whole thing.
By how exactly should i clean it? Sorry to sound so dumb...but im clueless.
The sensor is a green plug correct?
My oil pan is dented...could this also be the problem ? Thanks.
Modified by bluecivic11 at 5:09 PM 8/29/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluecivic11 »</TD></TR><TR><TD CLASS="quote">By how exactly should i clean it? Sorry to sound so dumb...but im clueless.
My oil pan is dented...could this also be the problem ? Thanks.</TD></TR></TABLE>
yes. yes.
unbolt it and spray it with brake cleaner to make sure the screen is clean. Dry out and reinstall.
yes. yes.
Modified by bluecivic11 at 5:09 PM 8/29/2007</TD></TR></TABLE>
read the thread before posting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod »</TD></TR><TR><TD CLASS="quote">So... how did you place in that rally? Any footage?</TD></TR></TABLE>
rally?
rally?
hey i got an 86 honda prelude 2.0 fuel injected and it wont start, the fuel pump went and then i changed it and it wont start all it does is turn over and the first time i turn it over it will start and rev up to about 2000rpm and then quit then it will just turn over i heard it cud be a bad battery feed to the injectors but im not sure got any info for me?
vtec93accord
Nov 3, 2003 08:09 PM
Anyone know a dismantler for honda? Maybe i can get a used one. Thanks.
