help.......cant get into reverse
Old Feb 16, 2003 | 01:30 AM
Acclude's Avatar
Default help.......cant get into reverse
why cant i get my h22a into reverse gear it goes into 1 2 3 4 5 ok but doess not get into reverse.........can anyone help??
Old Feb 16, 2003 | 04:55 AM
se93's Avatar
Default Re: help.......cant get into reverse (Acclude)
Recently i had that same exact problem. For no particular reason one afternoon i tried to get into reverse and was unable to do so. Later that day i took the car to my tech and he played around with the shifter for a while and got it going back into reverse gear. Truly strange and unexplainable.
Old Feb 16, 2003 | 06:04 AM
rjr162's Avatar
just hope it's a syncro or something really cheesy. My friend ripped a gear or two and wasn't able to get it into 1st, 2nd, 3rd, 5th, and reverse in his RX-7. Ended up having to get a new tranny off of ebay
Old Feb 16, 2003 | 07:58 AM
DR's Avatar
DR
Default Re: help.......cant get into reverse (rjr162)
I have had this happen twice now on my Prelude. Marcucci has written a very good write up on it here.
http://www.preludeonline.com/showthr...hreadid=106113
Old Feb 16, 2003 | 08:01 AM
ViZ's Avatar
ViZ
Default Re: help.......cant get into reverse (DR)
real racers dont need reverse
do any of your other gears grind at all? and when trying to get into reverse you try jiggling it into gear while you let the car roll a little?
Old Feb 16, 2003 | 08:19 AM
blacklude's Avatar
Default Re: help.......cant get into reverse (ViZ)
I just let out the clutch, re-engage it and try putting it in reverse again. usually does the trick
Old Feb 16, 2003 | 08:39 AM
topp_dawg_g's Avatar
From: springdale, arkansas, United States of America
hey i use to have the same problem too. i have a 94 honda prelude. to not make it stuck, if you are reversing already, and if you go back to neutral, try to stop before going back to reverse. if you don't make a stop, it will grind and may not go to reverse gear anymore. it happened to me twice. to fix it, step on the clutch very deep and and pull the gear to reverse very hard. it won't go in yet. then step a little gas, while slowly releasing the clutch to make the gear grind. making the grind may or will let a loose to the reverse gear.
Old Feb 16, 2003 | 09:00 AM
DR's Avatar
DR
Actually real racers do need a working reverse according to the SCCA GCR
Old Feb 17, 2003 | 05:20 PM
ViZ's Avatar
ViZ
maybe i should attach tags to jokes so its more obvious
(example: [joke]yo mama is so fat.... [/joke]
Cohgarrr13
Honda Civic (2001 - 2005)
Jan 8, 2018 05:05 PM
Eks_86
Dec 12, 2010 08:54 AM
si_ek
May 22, 2008 07:43 AM
SleekBlkPrelude
Feb 19, 2004 12:48 PM
