help...
Old Aug 25, 2002 | 04:15 PM
jdmSiT's Avatar
Default help...
what would cause the 'battery' light to come on while driving? when the light came on.. i pullled over.. turned the car off.. started it up again. 'battery' light went away.. but after driving for a couple of mins.. it came back on.
what would cause this?
thanks.
Old Aug 25, 2002 | 04:30 PM
RAB's Avatar
RAB
Default Re: help... (jdmSiT)
Battery light who cares, but check the voltage, you may need a new one. I'm sure you know that so this is a duh post.
Old Aug 25, 2002 | 04:58 PM
PrecisionH23a's Avatar
Default Re: help... (RY8127)
altenator could be going bad.
Old Aug 25, 2002 | 05:01 PM
cybercrx00
Guest
Posts: n/a
Default Re: help... (GudeH23a)
I second this
Old Aug 25, 2002 | 06:22 PM
Burte's Avatar
Default Re: help... (cybercrx00)
Eric, remember that autoX that I couldn't make because of my alternator....well guess what....hehe try this...start the car up then pull the pos battery cable off while its running...if the car shuts off...the alternator's bad....
[Modified by Burte, 3:25 AM 8/26/2002]
Old Aug 26, 2002 | 11:34 AM
JDM_CD7's Avatar
Default Re: help... (Burte)
Burte has a point .. try that.... if the light still come on just change the brushes inthe alternator... and you should be cool
Old Aug 26, 2002 | 11:41 AM
Elivi8's Avatar
I had the same problem and it was the alternator.
JasonST
Jul 15, 2018 03:29 AM
M3THTICAL(EF)
May 4, 2015 06:05 PM
uneek4dr
Mar 26, 2006 11:24 AM
JMX
May 25, 2005 06:39 AM
xsellxoutx
Apr 25, 2004 01:14 AM
