header/exhause rattle???
The other night i installed a high flow cat (Ractive, very cheap
) and ever since then ive had a rattle towards higher rpms. The rattle comes from the cat/ header area but i cant pin point it. Its a 96 si w/ dc header and stock exhaust.
Well if the rattle developed after the cat install, then the culprit is ____________.(Fill in the blank)
Sorry, I couldn't resist. Make sure it's not hitting a heat sheild. Those like to rattle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by five-0 »</TD></TR><TR><TD CLASS="quote">
Make sure it's not hitting a heat sheild. Those like to rattle. </TD></TR></TABLE>
I agree.
Also, make sure that the bracket that mounts the header to the block is secure tightly and check to make sure it isn't cracked.
I agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">Also, make sure that the bracket that mounts the header to the block is secure tightly and check to make sure it isn't cracked.</TD></TR></TABLE>
Header is good, and i took off the heat sheilds b/c there was no holes to secure them. any other suggestions?
o2flow.net
11
Jan 27, 2006 12:21 PM
