H23a compression test
Old Oct 8, 2002 | 07:49 AM
thao4life's Avatar
Default H23a compression test
Hi All, I recently did a compression test on my 92 si because I was losing a lot of low end torque. Plus my car seemed to be running really rough. The results of the compression test (plugs 1-4) are 120, 210, 195, 190. What is the range that i should be getting for a good engine? What does the low compression on cylinder 1 mean? Does this mean I need a new engine or would it be worth while to just rebuild my engine? Any help would be great..thanks
Old Oct 8, 2002 | 08:02 AM
BoostedH23a1's Avatar
Default Re: H23a compression test (thao4life)
ouch #1 is really low. they should be within 20psi or so of each other. 215 is what i have and 209 is my lowest. could be a head gasket but probaly your rings possible its your valvetrain too. if u have money get some crower rods, JE pisonts, and build that baby. 120 is really low.
Old Oct 8, 2002 | 08:42 AM
H23ludedude's Avatar
Default Re: H23a compression test (BoostedH23a1)
yep, 120 means you have a problem. On my motor at 103,xxx miles i got around 200-210. I think that you generally want them within 10% of each other.
Old Oct 8, 2002 | 03:46 PM
Si_LuDer's Avatar
Default Re: H23a compression test (H23ludedude)
how do you do a compression test? this isnterests me. my lude nas 190,000kilometers on the clock. and I'd love to know if Im losing power, since I bought the car it feels like I may have lost a bit. thought it could be the extra wieght and the high of the car or maybe even me getting used to the speed of it??
76 camaro car
Apr 20, 2017 04:47 AM
88 civic
Apr 5, 2009 03:21 PM
Hondizzle!
Sep 13, 2005 09:13 AM
tgod1020
12
Oct 9, 2003 04:29 PM
