H23 vtec
Old Feb 12, 2008 | 07:30 PM
waynecoSI's Avatar
Default H23 vtec
Ok, i just completed my h23 vtec build, its running and it does not want to idle worth a **** or anything. Its running off the p14 right now because i have not aquired a p13. it has the 345cc h22 injectors and i believe the h23s are 240's. would that make it run like total ***? its not out of time and all sensors are to the correct place. just looking for a bit of input. hope you guys can help.
Old Feb 12, 2008 | 08:18 PM
98vtec's Avatar
moderator emeritus
Default Re: H23 vtec (waynecoSI)
yes. that would make the engine not want to idle.
Old Feb 13, 2008 | 12:18 AM
Rosko's Avatar
Default Re: H23 vtec (98vtec)
definately. better hold off till you get the right ecu.
Old Feb 13, 2008 | 07:02 AM
IAluder95's Avatar
im with rosko. wait for the p13 or down grade injectors.
Old Feb 19, 2008 | 12:09 PM
waynecoSI's Avatar
Default Re: (IAluder95)
ok i got my p13 and it seems like its getting way too much fuel. My first problem was the rotor button in the dizzy came off somehow Im almost 100% positive the injectors are h22 340cc's. In the h23vtec how to thread it says you cant run the h23 injectors for it will blow the ecu fuse. Im honestly confused... maybe my injectors are bad or they are too big or what.
btw, when the p14 was on it, it ran decent and actualy would idle.....anyone have an idea???
Old Feb 19, 2008 | 01:28 PM
BUILT93ludeSi's Avatar
Default Re: (waynecoSI)
the ecu you run depends on the injectors you are running. H22 injectors will only throw a code if you have the P14, with the h23 injectors and p14 it is ok but with the h22 injectors you need the P13.
what intake manifold and throttle body are you using? im in the process of building my H23VTEC also
Old Feb 19, 2008 | 01:30 PM
Default Re: (BUILT93ludeSi)
check your vacuum lines also...
Old Feb 19, 2008 | 01:51 PM
waynecoSI's Avatar
all my vacuum lines are on, im using the h22 intake manifold, h22 injectors unless i got scammed on the injectors, and the h22 tb. basicaly everything from the head up is stock. im confused as hell. lol maybe my injectors are bad...any markings on the h22 injectors to tell if they are the h22's? like stamped p13 like everything else?
preludefien
Feb 4, 2007 08:22 AM
NeriVTEC
Jan 13, 2006 05:36 AM
PreLuDeSiR
Apr 26, 2005 10:15 AM
yohan
Sep 27, 2004 08:33 PM
Hbgsr
Nov 7, 2002 05:21 AM
