h23 distributor question
Old Jan 17, 2003 | 07:43 AM
dflipmode's Avatar
Default h23 distributor question
will the accord distributor work on the h23 with external coil?..and if so, what year accord should i go looking for...thanks for the help...
Old Jan 17, 2003 | 08:49 AM
dflipmode's Avatar
Default Re: h23 distributor question (dflipmode)
anybody?
Old Jan 17, 2003 | 09:24 AM
2point6's Avatar
no
Old Jan 17, 2003 | 01:22 PM
dflipmode's Avatar
Default Re: h23 distributor question (2point6)
coz the problem with my car right now is that its cranking but not producing any spark....i bought a brand new external coil and it ran for a little bit but died on my way home again and still has the same problem of cranking but not firing up...so it comes down to the distributor...it seems like if the car is cold it will start but when it gets hot...the car just dies........so if anybody has this problems before, shed some light ova here please and help me out. also is the h23 and h22 distributor the same the 92-95 h22 distributor?
[Modified by dflipmode, 5:59 PM 1/17/2003]
Old Jan 17, 2003 | 10:51 PM
Jeff33S's Avatar
I dont know if your whole distributor needs replacing, but it sounds to me like the ignitor in the distributor is bad and yes you can swap h series distributors around. except obd1->obd2 and vice versa
-Jeff-
Old Jan 18, 2003 | 10:51 AM
dflipmode's Avatar
Default Re: h23 distributor question (Jeff33S)
i replaced the cap and rotor but it still shuts down...it started when it was cold awhile ago...and after i replaced the cap and rotor.....it started for about maybe 4min and then it shuts down again....and now it wont start again...so somebody help me....thanks
Old Jan 18, 2003 | 11:10 AM
MrBui's Avatar
could be main relay....get to hot....car dies....
Old Jan 18, 2003 | 03:37 PM
dflipmode's Avatar
Default Re: h23 distributor question (n20need4vtec)
where exactly is the main relay located at?
also, can i use the h22 distributor for my h23?...i guess as long as it uses the external coil right..or does all h22a1 uses distributor with internal coil?
[Modified by dflipmode, 7:51 PM 1/18/2003]
Old Jan 18, 2003 | 04:32 PM
DirtyLude's Avatar
Old Jan 18, 2003 | 09:56 PM
hype r 555's Avatar
your best bet would be to go buy a msd cap with external blaster coil that way you dont have to worry about mix matching oe parts , the cap from a h22. may not fit considering the diff. in the heads
Old Jan 18, 2003 | 10:30 PM
dflipmode's Avatar
Default Re: h23 distributor question (bb4lude)
well i dont really have a problem with mix matching stuff....i was just wondering if i could use the h22 distributor considering if the actual problem is within the distributor itself...but i'm gonna check the igniter unit first thing tomorrow since its so damn cold ova here right now....i'm gonna check if i'm gettin any voltage from that...if not then i could probably just replace that unit itself with out replacing the whole distributor itself...i already got a new cap, rotor, and ignition coil anyways...so it narrows it down...
Old Jan 18, 2003 | 10:47 PM
Cottonwoodz's Avatar
Yes you can use a H22A1 dizzy in place of The H23A1 dizzy (They are exactly the same)
Old Jan 18, 2003 | 11:42 PM
dflipmode's Avatar
Default Re: h23 distributor question (Cottonwoodz)
thanks...if i cant fix the problem then i would try to see if i can get the distributor off the h22a1 instead....
DarkBB4
May 25, 2007 05:11 PM
tonezilla
Jan 31, 2004 12:16 PM
tonezilla
Jan 24, 2004 04:24 PM
