H22a distributor help
Old Aug 22, 2006 | 06:30 PM
vtec_lude's Avatar
Default H22a distributor help
Hi guys,
Been having dizzy troubles. Tried a friend's dizzy and the car starts fine so I assume my ICM has gone.
The thing is when I took the dizzy off I forgot to check which way the rotor was pointing.
I was just wondering if it does go in both ways or does it only go in one way?
If I do put it in the wrong way how can I tell? i.e idles rough?
Thanks for the help!
Old Aug 22, 2006 | 06:56 PM
v4lu3s's Avatar
RTFM
if it doesnt start its int eh wrong way, if its hard to push in its probably also in teh wrong way
Old Aug 22, 2006 | 09:11 PM
JasonST's Avatar
Default Re: (v4lu3s)
I'm pretty sure u can only put the rotor in 1 way, the side with threads to screw it into. Ur idle is probly rough because u didn't time it, each time u take ur dizzy off the timing is ganna be off, I suggest u mark it with a pen so u don't have to time it everytime. If u car doesn't start or have any spark with ur dizzy I'd check and replace the coil, only replace the ignitor (ICM) if ur tach was bouncing and car was bogging b4 it died.
Old Aug 22, 2006 | 09:21 PM
asmallsol's Avatar
yep it can only go in one way. the slot is slight thicker on one of the sides so you cant put it in 180 degrees backwards.
Old Aug 22, 2006 | 09:28 PM
v4lu3s's Avatar
RTFM
if you cant put it in backwards how come people all teh time post that they DID put it in backwards? all it takes is a little bit of force.
98jdmcivic
Oct 12, 2008 06:45 PM
mR. Vash
Sep 8, 2004 10:50 AM
SearchBeforeUPost!
Sep 24, 2003 01:01 PM
SearchBeforeUPost!
Sep 23, 2003 06:14 AM
SearchBeforeUPost!
Sep 21, 2003 06:40 AM
