H22a Auto?
Old Oct 8, 2002 | 12:06 PM
jakej's Avatar
Default H22a Auto?
A retarted machanic screwed up my h23-auto in my 92 4ws when he was tring to change the timing belt (at 80,000). Anyway, long story short... I new a new engine, but im low on funds. I know in japan you could get an h22a auto and the h23 auto bolts up to an h22a engine (or im told). I CAN NOT afford to do a manual swap right now, so im forced to do an h22a engine with the stock h23a auto tranny.
Now the problem.... is the ecu? Where the hell can I get an auto h22a ecu from? Could you get auto in the 5th gen's, or just SS?
Thanks! Thanks, Thanks!!!!!
-jake
Old Oct 8, 2002 | 03:55 PM
Si_LuDer's Avatar
Default Re: H22a Auto? (jakej)
probably best to look at import/honda parts wreckers for front cuts.. look for a jap spec 92/93/94 model, I believe thise have the older OBD1 ECU (correct me if Im wrong anyone). obviously the front ut has to be auto h22a and be one of the earlier models.. 95/96 has the OBD2 ecu again correct me if Im wrong
Old Oct 9, 2002 | 03:42 AM
jakej's Avatar
Default Re: H22a Auto? (Hypo-Si)
Isnt there a speed limiter on the jdm ecu's?
Could you get auto (non-ss) in the 5th gens? Because you can convert obdII ecu's to odbI easly, right?
Old Oct 9, 2002 | 05:11 AM
H23 Power's Avatar
just find a jdm auto p13 ecu...shouldn't be hard to find
Old Oct 9, 2002 | 06:29 AM
jakej's Avatar
Default Re: H22a Auto? (H23 Power)
any ideas on where to start looking?
Old Oct 10, 2002 | 11:53 AM
jakej's Avatar
ttt
b_hoov
Jun 12, 2010 03:11 PM
tapboyzlilj
Jan 8, 2008 12:53 PM
Chubs
Mar 11, 2003 12:27 PM
hungy
Dec 25, 2001 07:16 PM
