Check Engine Light
Old Oct 4, 2002 | 06:21 AM
SpeedGyrl's Avatar
Default Check Engine Light
I just recently bought a 99 Prelude. 2 days ago my check engine light came on. I know on Acuras and Hondas, if the gas cap isn't tight then the light comes on. However, it is on, oil is good, and nothing really seems to be messed up. The other day, while in park the engine kept revving. If anyone can help, I would really appreciate it. The local Honda dealership doesn't really have a clue.
Old Oct 4, 2002 | 06:53 AM
prelude1897's Avatar
Default Re: Check Engine Light (99LudeGyrl)
Reset your computer. Take the negative battery wire off for awhile, and then put it back on..Start your car, and see if the light comes back on. Sometimes you just need to reset the computer. If it comes back on, see what code it is throwing by counting the number of times it flashes
Old Oct 4, 2002 | 06:56 AM
GAperformance's Avatar
New User
Default Re: Check Engine Light (prelude1897)
http://www.c-speedracing.com/faq/03.html
Follow these directions. Then come back and tell us the code and we can make suggestions.
Old Oct 4, 2002 | 08:48 AM
ELUD THS's Avatar
New User
Default Re: Check Engine Light (bkw97lude)
agree check your ecu by your test plug in the 5th gens
Old Oct 10, 2002 | 06:55 AM
djskippe's Avatar
Default Re: Check Engine Light (ELUD THS)
Can someone tell me where the ecu & led are located on a 94ludeSI? Mine is also on and I need to find out why...
Old Oct 10, 2002 | 07:14 AM
satan_srv's Avatar
Default Re: Check Engine Light (djskippe)
Here you go http://www.hondaprelude.to/main_checkengine.html
Old Oct 10, 2002 | 08:05 AM
djskippe's Avatar
Default Re: Check Engine Light (satan_srv)
thanks....do you know if this applies to 4th gens? The article describes the process for a 5th gen.
Old Oct 10, 2002 | 08:17 AM
satan_srv's Avatar
It should....at least for the 96
Old Oct 10, 2002 | 12:21 PM
DsITR's Avatar
Had the same problem your talkin bout. only mine was throwing both ATTS, SRS and Malfunction Indc. had my ignition replaced (recall) and honda checked it for me and said it was a vacuum leak and low bat. fixed both, no more problems for a month now..Whenever you pull your bat to reset your car may turn it on later saying you have a low bat, so watch out for that.
peppers1245
Sep 3, 2008 09:03 PM
89civichb
May 10, 2007 06:42 PM
sherman
Honda S2000
13
Jun 22, 2006 04:13 PM
laurat
Oct 14, 2002 12:54 PM
VTECVillain
Jan 6, 2002 11:40 AM
