H22 Engine Overhaul Kit
Old Nov 12, 2005 | 02:36 AM
Yuleluder's Avatar
Default H22 Engine Overhaul Kit
I wanted to know where I could find a good engine ovehaul kit. I'm looking for a kit that has practicaly everything in it. Like main bearings, rod bearings, all gaskets, oil pump, rings, etc. Tried to do a search but it says the search server is down.
Old Nov 12, 2005 | 04:49 AM
92hondalude's Avatar
Default Re: H22 Engine Overhaul Kit (Yuleluder)
you can buy the whole gasket set from inlinefour
and then you can buy pistons and rings from them
i dont know if they have main bearings or not but they might be able to order them for you just make sure your getting the right size
Old Nov 12, 2005 | 08:25 AM
MadCityLude
Guest
Posts: n/a
Default Re: H22 Engine Overhaul Kit (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">you can buy the whole gasket set from inlinefour
i dont know if they have main bearings or not but they might be able to order them for you just make sure your getting the right size </TD></TR></TABLE>
inlinefour? I have never heard of them? do they make quality parts?
I would suggest going to a HONDA dealer myself. Then you know you are getting quality parts!
It doesn't sound like you are upgrading or changing any of the internals are you? Just a basic rebuild?
Old Nov 12, 2005 | 10:04 AM
Yuleluder's Avatar
Default Re: H22 Engine Overhaul Kit (EuroR92Lude)
I am replacing the block because of scratches on the #3,#4 cylinders. I am using Type S pistons in the block. The head was done by GUDE, a few months ago. Just want to replace every gasket, bearing and seal when I rebuild the motor. I don't want to short cut anything.
Old Nov 12, 2005 | 10:08 AM
MadCityLude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yuleluder &raquo;</TD></TR><TR><TD CLASS="quote">I am replacing the block because of scratches on the #3,#4 cylinders. I am using Type S pistons in the block. The head was done by GUDE, a few months ago. Just want to replace every gasket, bearing and seal when I rebuild the motor. I don't want to short cut anything.</TD></TR></TABLE>
why no sleeve it? use an H23 crank?
Old Nov 12, 2005 | 11:37 AM
Yuleluder's Avatar
Default Re: H22 Engine Overhaul Kit (EuroR92Lude)2
I have a H23 crank, and I was thinking about it, but I changed my mind. Resleeving is out of the budget at this point. I am getting the clip, just to get the manual transmission, and other parts that I need to do the auto to manual conversion. The clip has the M2B4 tranny. Looking to get a lightened flywheel and clutch. The guy said he thinks the clip has a performance clutch in it, so I'll wait until I crack into it before I get a clutch.
Old Apr 11, 2022 | 11:26 PM
H22A_CL1-EuroR's Avatar
reviving this cuz I wanna rebuild my H22A and cant find the right kit!! Need help!
Old Apr 12, 2022 | 09:40 AM
ross2004's Avatar
You're not going to find it. You'll need to piece together a lot of the separate components.
Old Apr 12, 2022 | 01:43 PM
Icon5 Re: H22 Engine Overhaul Kit
ahh alrightyy.. Another thing I'm tangled up with is the engines... I've been told that the H22A1 gaskets and seals fit the JDM H22A but is different for the H22A4 engine... I know that H22A1 and A4 are the USDM engines.. plus, the engine I'm planning to rebuild came out of an 1998 Prelude, which to my knowledge is JDM H22A.. I want to rebuild that engine and throw it into the Accord.. will it have any effect on the performance ...
Sorry if my questions **** you off ...
Old Apr 13, 2022 | 05:31 AM
ross2004's Avatar
The biggest (and maybe only, I'm not sure) difference in gaskets is the head gasket- which is a matter of open vs. closed deck blocks. I can't think of anything else that would be different aside from the oil pan gasket (steel vs aluminum pans).
longlivekel1
Jul 12, 2011 06:28 PM
mjfx
Jun 26, 2007 07:47 PM
GruvyTune
Jan 20, 2005 01:48 PM
pg_thao
Mar 28, 2003 07:48 AM
karmannghia
Apr 30, 2002 10:15 AM
