Opinion on aftermarket re-ring project
Old 07-10-2011, 04:13 PM
longlivekel1's Avatar
Default Opinion on aftermarket re-ring project
Hey guys,
I have a d16z6 and it said 75k on the cluster of the car I pulled it from but am not sure if I should trust it. So I am rebuilding it. Everything looks great inside of the engine but I figured that I have it torn down, I might as well do a re-ring kit. I do not trust the master over haul kits online since they do not state what companies make what.
I then looked at majestic honda's prices and 27 bux for piston rings for 1 piston. That is a little out of my budget.
I am just going to do a stock engine rebuild. Standard piston rings and bearings. I have no fear in buying a felpro gasket set. I have rebuilt many engines with them and have awesome luck. Being a honda, I do not have a lot of experience with rebuilding them.
I have heard that sealed power is good and they make a rering kit for this engine but I have never used their products.
Who do you suggest for thrust washers, bearings, and rings?
I don't mind making my own kit!
Thanks!
Old 07-12-2011, 06:28 PM
Default Re: Opinion on aftermarket re-ring project
Ok guys I used the plastigage tonight...
Here is what I got.
Rod Bearings
Cylinder 4
Bearing color Yellow
The plastigage smudge was close to 1/64" narrower than .0015
Cylinder 3
Bearing color Green
Cylinder 2
Bearing color Green
The plastigage smudge was close to 1/64" wider than .0015
Cylinder 1
Bearing color Green
Main bearings from left to right (cylinder 4 is on the left)
Main bearing 5
Bearing Color Brown
Main bearing 4
Bearing color Green
Main Bearing 3
Bearing Color Green
Main Bearing 2
Bearing color Green
Main Bearing 1
Bearing color Green
The plastigage smudge was exactly .0015
Judge Owens
11
03-16-2014 09:54 AM
FOKAI95
08-01-2012 08:19 PM
dgie
12
07-06-2008 06:41 AM
Hoosier Daddy
09-29-2003 02:49 PM
pg_thao
03-28-2003 07:48 AM
Quick Reply: Opinion on aftermarket re-ring project
