h series engine help
Old Jul 25, 2010 | 07:33 AM
lilrobie69's Avatar
Default h series engine help
ok i have a 97 bb6 with the h22a4 and like others with that engine i have started burning oil after 100,000.. and want to rebuild.... but ive been told b/c of the dame carbonsteel sleeves it cant be board or hoaned and the cant be removed from the block....so is thi true or not and wtf should i do to rebuild?
Old Jul 25, 2010 | 12:05 PM
InvaderTrax's Avatar
Default Re: h series engine help
Search. First step is to find out if it's your rings or valve seals that are causing your oil smoke. FRM can be bored if needed
Old Jul 25, 2010 | 03:52 PM
MmKilla's Avatar
yeah i heard they can be bored, but not that much, my 97 sh has 160,000 on it, i believe it was burning oil as well, but i did numerous compression and leakdown tests on it, and my problem was the valve seals, and my exhaust valves not seating all the way, i sent my head to a machine shop for tests, and everything came back good. the head has new valve seals, and all the valves were cleaned. it also got a valve job, pressure testing, and vacuum testing done as well. Although they told me my exhaust valves were bent, so had to replace them, but when i get it back on the car i'll post up, if everything goes back to normal.
Old Jul 26, 2010 | 11:20 AM
Rude Awakening's Avatar
Daughter not possible
raverx3m
17
Sep 17, 2013 12:01 PM
integra123
Sep 25, 2008 09:09 PM
Yuleluder
Aug 7, 2007 08:10 PM
si937
Jul 25, 2006 02:18 PM
turbociv
38
Jul 4, 2004 11:33 AM
