G23 Build Help!!!
Old Jan 22, 2015 | 03:18 PM
Hector Valencia's Avatar
Default G23 Build Help!!!
Can i use aftermarket F23 rods with stock K20 pistons?
Old Jan 22, 2015 | 07:47 PM
lexrob's Avatar
Default Re: G23 Build Help!!!
A quick Wikipedia search says a f and k series both have a 86mm bore.
Id just call a machine shop familiar with Hondas. Bisimoto or something.
Or you could get ahold of some service manuals and find the piston deck height and all that stuff.
I say they could be used just a matter of how much the piston pin has to be moved if at all. Also how much or if the tops of the pistons need to be milled down.
I can tell you recommended piston to head and piston to valve clearance are about .045 minimum.
Sorry that's all ive got. Good luck!
Old Apr 11, 2015 | 01:52 PM
Myfastcrx's Avatar
Did you end up using this piston and rod setup?
Pellegrini808
Sep 14, 2013 04:09 PM
machine4321
Nov 24, 2005 11:15 PM
heretolearnandteach
Oct 25, 2005 05:21 PM
gaskleppie
Apr 14, 2004 09:34 AM
alfee
Mar 28, 2004 10:08 PM
