Piston assembly
Old Oct 24, 2005 | 06:23 PM
heretolearnandteach's Avatar
Default Piston assembly
Hi, I just recently assembled my first motor. Its a 94 b18b1. I had it honed and decked by a good local machine shop who measured the bore and said it was still at perfect specs. When taking it apart the stock pistons were in good and tight. I replaced the internals with SRP 9.2:1 81mm pistons and Eagle rods with Je High tension rings. When I installed the pistons I had to tap them in with a rubber mallet into the bore. They had a reasonable amount of resistance when pulling them up and down and felt right. However when I put a thumb between the intake or exhaust valves and pushed side to side I could very lightly "jiggle them" My machine shop said it was because they are forged pistons they have a little extra clearance for expansion, Is this true? Does it sound like everything is fitting correct. This is my first build so im not really sure, however the people at the shop said it sounded right and it may be because the rings need to seat, but the specs were correct. Thanks
Old Oct 24, 2005 | 06:56 PM
NJIN BUILDR's Avatar
Default Re: Piston assembly (heretolearnandteach)
They are correct.The forged pistons have two to three times the clearance that the cast ones had.
Glenn
Old Oct 24, 2005 | 07:04 PM
SOHCD16y8's Avatar
yeah I had the same questions on my first build.
Old Oct 24, 2005 | 07:06 PM
Default Re: (SOHCD16y8)
Thanks for the responses, that puts me at ease. Anyone else agree with them?
Old Oct 24, 2005 | 08:22 PM
2k.civic.si's Avatar
Default Re: (heretolearnandteach)
if your super worried just get a digital caliper measure the piston then measure the cylinder wall and see exacly how much clearance you have....your pistons should have a spec sheet with them that gives clearance range
Old Oct 24, 2005 | 09:32 PM
AbitAvenger's Avatar
Default Re: Piston assembly (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">They are correct.The forged pistons have two to three times the clearance that the cast ones had.
Glenn</TD></TR></TABLE>
Old Oct 25, 2005 | 05:04 PM
The machine shop measured the bore and said it was fine, and the pistons are 81mm so im not to worried. The "jiggle just worried me for a minute there. Thanks
Old Oct 25, 2005 | 05:19 PM
abnaasefmb's Avatar
u r good, keep rocking! post dyno when done!
Old Oct 25, 2005 | 05:20 PM
abnaasefmb's Avatar
Default Re: (abnaasefmb)
oh yeah and thanks for the sig!!!!!!!!!!!!!!!!!!!! that dude was a TOOOOOOL! haha
Old Oct 25, 2005 | 05:21 PM
SOHCD16y8's Avatar
LMAO (looking at sig)
Pellegrini808
Sep 14, 2013 04:09 PM
hatchinprogress
Nov 14, 2005 08:36 PM
boostedinteg03
Apr 15, 2003 12:06 PM
