Fog Relay!!!!!
Old Sep 21, 2005 | 09:07 AM
XtremeSpeed's Avatar
Default Fog Relay!!!!!
Ok, so i set up my fog lights. and i plugged in the relay. now when i turn my lights on, and turn on th fogs, i can hear the relay turn on, but it makes a buzzing noise and WONT stop. what did i do wrong?? its the relay straight from honda.
Old Sep 21, 2005 | 09:15 AM
Default Re: Fog Relay!!!!! (XtremeSpeed)
also, when i switch on the high beams, they stay on
Old Sep 21, 2005 | 09:27 AM
IAluder95's Avatar
bad relay.
Old Sep 21, 2005 | 10:05 AM
thats it? i didnt do anything wrong?? i just wanna make sure cuz im picking up another one tomorrow and i dont want the same thignto happen. thanks
Old Sep 21, 2005 | 10:06 AM
Lewdin' Incognito's Avatar
Default Re: (XtremeSpeed)
What kind of relay is it? Maybe you wired it up wrong?
EDIT: Sorry I thought you meant you had wired in a new relay with it...
Modified by Lewdin' Incognito at 11:24 AM 9/21/2005
Old Sep 21, 2005 | 10:21 AM
its the honda relay. i dont think i could have wired the relay up wrong, since its plug and play. as far as wiring the switch wrong, i know whichone connected to what. the orange went to the black. red/yellow to red/yellow. and the red/black to red/green
Old Sep 21, 2005 | 10:32 AM
also, right now, with the fog switch off, they r still on, and they turn off with the hig beams, but when i turn on the switch, they stay on, even when the high beams r on, and the relays makes that buzzing sound
Old Sep 21, 2005 | 11:04 AM
PreLuDeSiR's Avatar
how much was the relay at the dealership?
Old Sep 21, 2005 | 11:25 AM
$49....anyone have an asnwer though????
Old Sep 21, 2005 | 12:21 PM
VtecPrelude95's Avatar
http://64.233.167.104/search?q...ng_en
try going there....i got my relay from them and it works fine. the fogs only come on when the driving beam is on, when u high beam it turns off, when u turn the headlights off the fogs turn off also. im pretty sure thats how the stock ones suppose to work. i juat wish that theyd stay on when the parking lights are on instead of having to turn all the lights for them to work.
Old Sep 21, 2005 | 03:13 PM
i already have the relay from honda, i dont need another one, i just need to make sure that this one is just deffective. when the switch if off, the fogs work perfect(turn on when the lights turn on, off when i turn the high beams on) but when i turn the switch on, it makes a bizzing sounds from the relay and the fogs stay on regardless is the high beams r on or not. also when the switch is off, the indicator light on the switch turns on by itself as soon as i turn on the lights. any ideas?
Old Sep 22, 2005 | 09:39 AM
bump..just picked up the new relay from honda...someone please tell me if i did it all correctly, i dont wanna burn this one if it was my fault last time.
Old Sep 22, 2005 | 09:47 AM
PreLuDeSiR's Avatar
can I use any generic automotive 4 pin relay for the fogs?
Old Sep 22, 2005 | 10:31 AM
bump, can someone please answer my question instead of asking ur own?!? search it has been covered. apparently yes, but i dont know which ones work..
also, does the relay need to be grounded at all??(the bracket is metal and its supposed to mount to the cruise control unit bolt, so i didnt know if that was coincidence, or its a ground)
Old Sep 23, 2005 | 01:42 AM
303's Avatar
303
the relay is a direct plug in to the harness, no need to ground
Old Sep 23, 2005 | 08:42 AM
what about the switch? did i do that correctly? the 3 color wire3 on the stock harness were orange, red/yellow, and red/green. the switch had black, red/yellow, and red/black. i connected black to orange, red/yellow to red/yellow, and red/green to red/black. is that right?? its the JDM switch and i have a 96
Old Sep 23, 2005 | 03:08 PM
bump
Old Sep 24, 2005 | 05:14 AM
bump..come on guys, i just need an answer before i put the new relay in.
Old Oct 1, 2005 | 12:04 AM
303's Avatar
303
this is what i've experienced. mine buzzed when the high beams/fogs were "on" and high beams "on"/fogs "off", also with the switch "off" for both, but not when lows/fogs were "on". i changed the indicator light(burnt out) and that fixed those problems. if i have my lows "on" and fogs "off" it buzzes. so, when i have my lows "on", my fogs are "on" as well. there is another indicator in the switch, i don't know what it does (possibly as a resistor?). maybe that could somehow be the cause of my continued buzzing when all are "off", or the switch is worn so the current leaks through. i may take the switch apart and use some contact cleaner on it. i think this because the indicator has a dim illumination when fogs/headlights are "off". maybe someone else knows? oh, and i have my switch(jdm) wired the same as yours.
Old Mar 9, 2006 | 03:54 PM
EOE's Avatar
EOE
Default Re: (303)
Anyone solve this, Im getting this now.
Old Mar 13, 2006 | 06:24 PM
EOE's Avatar
EOE
BUMP
Everything done right, only thing is I had to short the switch to get them to work because I don't have a switch. But buzzing is still there. ARGH!
cheap_noob
May 5, 2012 02:48 PM
JusAccord
Mar 29, 2012 06:38 PM
GS8HFL21
Nov 9, 2005 06:56 AM
Feuerraeder
Audio / Security / Video
Mar 15, 2002 06:43 AM
