F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
#1302
Re: (Sam1am26)
Ah man ( 1700anddropping) that's totally what I want to do ( minus nos) but, I would want it for my daily . ppeople still going " no no a deck plate won't last , it's not streetable"... I figure technology should be better than 3 years ago so I may being trying this when I get back from Japan in 2007.
Please keep us up to date on progress and, wear and tear on the plate
#1303
Re: (spirit7627)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirit7627 »</TD></TR><TR><TD CLASS="quote">Ah man ( 1700anddropping) that's totally what I want to do ( minus nos) but, I would want it for my daily . ppeople still going " no no a deck plate won't last , it's not streetable"... I figure technology should be better than 3 years ago so I may being trying this when I get back from Japan in 2007.
Please keep us up to date on progress and, wear and tear on the plate</TD></TR></TABLE>
thanks man and will do.
stay safe.....
stay safe.....
#1307
Re: (SB tuning)
I read that the vtec oil port was pluged on the f22. Is this the port and if it is how do i get it out.
http://community.webshots.com/...IGtjh
Modified by ChaosUnbound at 11:59 PM 12/27/2005
#1309
Re: (ChaosUnbound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaosUnbound »</TD></TR><TR><TD CLASS="quote">I read that the vtec oil port was pluged on the f22. Is this the port and if it is how do i get it out.
Modified by ChaosUnbound at 11:59 PM 12/27/2005</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning »</TD></TR><TR><TD CLASS="quote">screw a 10mm bolt and pull it out </TD></TR></TABLE>
thats exactly what i did, just thread anything into it that will work and pull, its only sitting in the hole held in with a tight fit oring.
#1311
Re: (ChaosUnbound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaosUnbound »</TD></TR><TR><TD CLASS="quote">thanks i didnt know if it was threaded in there or not</TD></TR></TABLE>
yeah it is
yeah it is
#1313
Re: (FlatBlackPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackPrelude »</TD></TR><TR><TD CLASS="quote">UPDATE-Started my project today-YEAH!!!!</TD></TR></TABLE>
thats good to hear, keep us updated, maybe one day someone who builds one of these will have the money to get it dynod .. lol
#1314
Re: (prelittlelude)
well fella's i have finally landed a job after being out of work for
dam near 5 months.just letting everybody know that my set up
will be done by the first of SUMMER.
progress will begin shortly and when it starts it will come w/a VEGENCE
Modified by 1700anddroping at 2:32 AM 12/31/2005
#1315
my project almost complete...waiting on the eliminator kit and head plugs from RMS
setup:
usdm h22 head milled .010"
type s camshafts
98 f23a5 block
03 rsx-s pistons
aebs head studs
fidanza 8lb flywheel
act6 puck unsprung
m2f4 trans with new syncros
megan header
66mm throttle body
3" exhaust 4m header back...
Modified by SB tuning at 12:05 PM 1/3/2006
setup:
type s camshafts
98 f23a5 block
03 rsx-s pistons
aebs head studs
act6 puck unsprung
megan header
66mm throttle body
#1318
#1319
Re: (SB tuning)
I've been reading this thread from the beginning for 3 hours and have gain alot of knowledge from the OP (prelittlelude) Kid, I'm from Mass. too is there any way I can come and see the motor?
#1321
Re: The cats out of the bag: F22b2 block+H22a1 head (prelittlelude)
I'm new to the board, and this thread is awesome!! I am working with a 96 Accord F22. It is my younger brothers car and we planned on the H22 swap. Make a long story short we bought the engine/trans/ecu and had to send it back today because it was damaged. I read the thread once then skimed over it. Okay F22 lower end H22 head, H23 headgasket, H22 water pump gear. Did I miss something? What about wiring did I miss something? We are going to do this with a little twist. Going higher compression 10.5 - 11.5 and bore it to 86mm. Do we need the intake from the H22?
Thanks,
Allan
Thanks,
Allan
#1323
Re: The cats out of the bag: F22b2 block+H22a1 head (Defiant7m)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Defiant7m »</TD></TR><TR><TD CLASS="quote">I'm new to the board, and this thread is awesome!! I am working with a 96 Accord F22. It is my younger brothers car and we planned on the H22 swap. Make a long story short we bought the engine/trans/ecu and had to send it back today because it was damaged. I read the thread once then skimed over it. Okay F22 lower end H22 head, H23 headgasket, H22 water pump gear. Did I miss something? What about wiring did I miss something? We are going to do this with a little twist. Going higher compression 10.5 - 11.5 and bore it to 86mm. Do we need the intake from the H22?
Thanks,
Allan</TD></TR></TABLE>
use the f23 head gasket not the h23. you need head plugs too like pictured on the page before.
also try gettting some rsx pistons that will get you pretty good compression, and you will only have to bore the f22 out to 86mm. either that get some shelf forged
pistons at 85mm.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridpatient95 »</TD></TR><TR><TD CLASS="quote">geeez sb tuning... resize your pictures...
is it possible to use the h22 timing belt mount that goes on the block? </TD></TR></TABLE>
on an F block im assuming your asking? I used it but it deosn't line up right. 2 out of the 3 orginal holes line up , and then i dremeled the additional 4th hole to fit. I also sits at a different angle now because the h22 mount holes are different than the f22. but the rubber mount that the motor bolts into takes up this different angle.. but your better off using the f22 mount.
Thanks,
#1324
Re: (VIPTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VIPTuning »</TD></TR><TR><TD CLASS="quote">I've been reading this thread from the beginning for 3 hours and have gain alot of knowledge from the OP (prelittlelude) Kid, I'm from Mass. too is there any way I can come and see the motor? </TD></TR></TABLE>
id be glad to meet up with you somewhere any take you for a ride.. in the spring that is..
