error code P0441
Old Apr 30, 2010 | 08:04 AM
kornkid21792's Avatar
Default error code P0441
wich is evap system Insifficient Purge Flow
Purge Flow Switch Malfunction
i really have no idea how to fix this looked at the helms and it just isnt making any sense to me any help would be much apperciated
Old Apr 30, 2010 | 11:50 AM
92civlude's Avatar
Default Re: error code P0441
Check the purge solenoid. Its located next to the cruise control actuator. It should click "purge" when the engine is warm and running. Check the black/yellow wire for 12v. Ground the red/yellow wire with a backprobe. This will give the solenoid full command and there should be vacuum on the outlet side of the solenoid. If there is no vacuum, the solenoid is bad.
Old Apr 30, 2010 | 11:34 PM
is it the one with the hose leading to the top of the thorttle body or the one behind the cruise neither one was clicking
Old May 1, 2010 | 09:52 AM
92civlude's Avatar
You must have a 97 model prelude. These differ slightly than other 5th gens. Your best bet is take it to a dealer.
Old May 1, 2010 | 10:29 AM
Kronn 98SH's Avatar
^ Stupid answer.
Any difference will be noted in the Service Manual.
Old May 1, 2010 | 03:12 PM
92civlude's Avatar
Originally Posted by Kronn 98SH
^ Stupid answer.
Ha Ha Kronn! This system is more elaborate than other systems. It might not be possible for a novice to repair. Im not going to post by post all the steps required to diagnose this car. Especially component location. You offered the same reponse. "Check the service manual" or "find a Honda tech" offer the same value. NONE. So my answer is just as stupid as your answer.
Old May 1, 2010 | 03:37 PM
Kronn 98SH's Avatar
He'd still be better off taking it to a mechanic vs the stealership. Even though I'm sure he can tackle this himself. Just read the section a few times and it'll make sense.
Kornkid, if you need, I can post any wiring schematic for our cars.
Old May 1, 2010 | 07:09 PM
92civlude's Avatar
Well get it done son. Good intentions wont fix the car!
Old May 2, 2010 | 12:38 AM
i am somewhat insulted lol i am by no means a novice. just new to the obd2 preludes thats all.
ya thatd be cool id apperciate that.i am going to just switch to obd1 though so i think that will take care of that problem
hah not like i have atts i dont care about obd2
and as usual i thank you for the advice
Old May 2, 2010 | 12:18 PM
92civlude's Avatar
Sorry about that! I really dont understand why Honda used a purge switch on 97 5th gen. If you decide to go OBD2 and Kronn hooks you up with a diagram, The purge switch is that round component near the throttle body. Good luck Kornkid.
Old May 2, 2010 | 02:01 PM
its all good man ya it is wierd that they did that. and thanks ya i found it i think its a bad one or something if i reset ecu it will click and all that good stuff then about 40 miles later it stops
Old May 2, 2010 | 05:41 PM
92civlude's Avatar
OK, good. When it stops clicking, disconnect outlet the hose on the purge solenoid, leave the vacuum hose to the manifold connected. With the engine running, ground the red/yellow wire. There should be manifold vacuum present at the hose. If not, the purge solenoid is bad for sure.
Old May 2, 2010 | 07:24 PM
ok ground the wires thanks and do i just pop it out of its socket and ground it that way or what.
thanks again for the help
i always knew people from my old city were good
Old May 2, 2010 | 07:54 PM
92civlude's Avatar
No, leave it plugged in. You can backprobe it with a sharpened paperclip or similar. Your always welcome to come back to ABQ! Cool Honda crowd here.
Leviatard
Sep 13, 2015 04:57 AM
buckgrunter
53
May 28, 2015 10:58 AM
maddmatt02
Jun 11, 2009 08:55 PM
Rxtc
Jun 5, 2008 05:28 AM
