Error code help :/
Old Apr 22, 2004 | 07:49 AM
Prelude MIke's Avatar
Default Error code help :/
Well i got a new ECU and that was supose to fix a Code 9 problem i had. The old ecu was damaged so thats what i thought it was. Well i did a tune up changed everything poped the new ecu in and bam here is the code 9 again. I looked it up and it said CYP sensor.
Ok heres the question, is this sensor (code 9) able to be replaced. and if it is where is it?
Old Apr 22, 2004 | 08:02 AM
OTT's Avatar
OTT
code 9= Cylinder 1 Position
All the sensors are replaceable, not sure where that is though
Old Apr 22, 2004 | 11:29 AM
Default Re: (OTT)
thanx i feel a tad better, least it can be replaced
Old Apr 22, 2004 | 12:51 PM
prelittlelude's Avatar
Default Re: Error code help :/ (Prelude MIke)
the CYP seonsor is part of the distributer assembly, check that all your wires are ok going to the distributer, maybe even open up the dizzy and see if everything is spic and span in there
Old Apr 22, 2004 | 12:54 PM
Default Re: Error code help :/ (prelittlelude)
ok kool ima chk that out now. Clean it up best i can. Any clue what this sensor looks like? if it needs to be replaced that is.
Old Apr 22, 2004 | 01:22 PM
well i opend it and cleaned her out and still getting code 9. car starts up fine, but about 3 seconds after she starts chk engine light pops on and the car runs like poo.
The Wires all going to the sensor are fine as well. I guess that sensor needs to be replaced. I called up honda and they said i need to buy the entire distributor assembly, and thats like 300+ bucks. Or are they correct and i have to bite the bullet?
Modified by Prelude MIke at 10:35 PM 4/22/2004
Old Apr 22, 2004 | 01:45 PM
Speedra500's Avatar
It depends on what year prelude as to where the cylinder position sensor is, what year is your prelude?
Old Apr 22, 2004 | 02:02 PM
Default Re: Error code help :/ (Speedra500)
i have a 1992 prelude with a 1995 H22A prelude Vtec engine swap, and i belive ive located it inside the cap. Its a black curved piece seems to have 2 screwes holding it in place(not 100% its able to be unscrewed i havnt tried)
Old Apr 22, 2004 | 03:30 PM
bump
Old Apr 22, 2004 | 04:03 PM
JDMSloLude's Avatar
Chances are you will have to replace the entire distributer. If so just get one from distributer King and mention Honda-tech, I got one for an H22 overnighted for $200.
Old Apr 22, 2004 | 05:55 PM
Default Re: Error code help :/ (JDMSloLude)
awsome thanx saved me 100 bucks
Old Apr 22, 2004 | 07:34 PM
just curious anyone have an idea why this sensor just went? just seems odd...
superslowcrx91
Sep 30, 2013 12:54 PM
hatch96y7
Nov 19, 2007 10:58 AM
T--Rex
Jul 10, 2004 02:15 PM
USDM 4G VTEC
11
Jul 15, 2003 11:05 AM
White Lightnin
Jun 28, 2002 09:15 AM
