Engine Check Light
Old Apr 15, 2003 | 07:53 PM
92-h23a1's Avatar
Default Engine Check Light
i'm not sure what the problem could be but it usually happens when i'm driving on the highway on 5th gear. the engine light goes on right about then, not sure what is the problem. but when i'm driving in local streets on like 1-2-3-4 its fine. after the engine light is on when i stop and turn off the engine, it won't start after a while. would anyone know what the problem could be?
Old Apr 15, 2003 | 07:57 PM
sslude's Avatar
Default Re: Engine Check Light (92-h23a1)
what the code? my check engine light comes on after about 100+ MPH because of the VAFC. but i dont think you have one.
Old Apr 15, 2003 | 08:00 PM
92-h23a1's Avatar
Default Re: Engine Check Light (sslude)
Code? Not sure but I'm assuming it could have something to do with my coolant or water pump? what do you think?
Old Apr 15, 2003 | 09:07 PM
littledan's Avatar
i just picked up a 95 srv and that has been happening to me as well. when i shut off the car and start it back up the light has dissappeared. the inspection didn't catch anything... any ideas guys?
Old Apr 15, 2003 | 09:22 PM
DsITR's Avatar
Default Re: Engine Check Light (littledan)
Pulling the code is the only way to get a definate relibale answer.
We can postulate and assume all day...but it probobly won't help you much.
Anyone have a link on pulling the codes??
Old Apr 15, 2003 | 11:09 PM
PreludeRacer023's Avatar
Default Re: Engine Check Light (dsludefosho)
remove your radio...there should be two plugs back mounted oh the metal frame..its the 2 pin plug..i believe its a blue plug, take a small piece of wire, strip it on each end, stick the wire into each opening on the Blue plug, thus jumping it, then turn your car to the ON position, your check engine light will flash if theres a code..each long flash is 10, short ones are 1..so for instance, if it goes blink blink blink blink..all short thats 4..youd then look up CEL 4 in a manual or ask one of us here...or you might get, long flash long flash, short short short....that would indicate 23..and so on, pull your codes until they repeat themselves..so that you know you got them all..start there..peace
Old Apr 15, 2003 | 11:27 PM
littledan's Avatar
Default Re: Engine Check Light (PreludeRacer023)
that is a great tip... i will try that as soon as my exams are done... i noticed those plugs when i installed my deck a few days ago but did not know what they do
Old Apr 16, 2003 | 06:57 AM
577HondaPrelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what the code? my check engine light comes on after about 100+ MPH because of the VAFC. but i dont think you have one.</TD></TR></TABLE>
Why does the VAFC make your light come on after 100+??
blaze.1
Sep 24, 2009 11:04 AM
ryanminer
Oct 17, 2008 08:52 AM
eg686
Apr 18, 2003 01:01 PM
wadafa
11
Oct 3, 2002 03:49 PM
