egr help!!!!!!!!!!
Old Dec 7, 2004 | 08:30 PM
dtran002's Avatar
Default egr help!!!!!!!!!!
i have a 95 accord wit a jdm h22a, and the egr line is not connected, but the valve or the lil thingy is there, so anyone noe how to connect the wire together? any diagram or something? thanks alot
Old Dec 7, 2004 | 08:58 PM
coupon's Avatar
Default Re: egr help!!!!!!!!!! (dtran002)
i thoguht if you had obd1 you dont have to worry about the egr? its not giving you a cel or anything right?
Old Dec 8, 2004 | 07:26 PM
dtran002's Avatar
Default Re: egr help!!!!!!!!!! (slowredhybrid)
i got obdI and it throwin me with that code, it juss annoyin to see the engine check light on thats all, im plannin to get p28ecu but dunno if i can juss bypass the secondary butterfly or have to change the intake manifold
Old Dec 8, 2004 | 09:13 PM
ludegetsmwet's Avatar
obd1 should not give you a cel. if your going p28 you will not be able to use your secondaries so either remove them or get the edelbrock or skunk2 im. there should be an electrical connector right there that sends a signal to the egr to control the lift valve inside of it. Just connect the connectors. don't know what else to tell ya
Old Dec 9, 2004 | 05:11 AM
Daily Interlude's Avatar
My OBD1 P13 gives a CEL for EGR.
Anyone know if changing to a P28 would be best mated with a different manifold (one w/o butterflies)? I want to get rid of my EGR too...
Old Dec 9, 2004 | 07:17 AM
v4lu3s's Avatar
RTFM
if your egr is nto hooked up it will give a code 12 on obd1.
and usually you jsut plug the wiring side lug into the egr lift sensor....usually that is
do you have a sqaure or round plug on the harness side?
HamiltonRex
May 3, 2011 04:08 PM
BeyondTheCompetition
Mar 14, 2008 10:56 AM
jeffchaisi
Mar 23, 2005 10:28 PM
DarkBB4
Nov 8, 2004 05:08 PM
frostee
Sep 30, 2004 10:28 AM
