ECU, does it work imediately?
Old Dec 6, 2004 | 10:27 AM
white lude's Avatar
Default ECU, does it work imediately?
I finished a h22 into a h23 prelude, my problem now is i dont feel like i have enough power. As i drive the car it seems to be running better but not perfect. So my question - does the ECU need time to adjust to the engine? Or should i just go get it dynoed. ive only had the car up and running for 3 days.
Old Dec 6, 2004 | 10:32 AM
AndyD's Avatar
Default Re: ECU, does it work imediately? (white lude)
Give it a few days. Who knows how long your motor has been sitting without being run.
Mine took a few days to run well. My hesitation is KIND OF went away. My car was a little sluggish when I first drove with the H22. My h23 ran perfectly though. I did notice the difference in bottomend torque.
Drive it around, flush out the oil after a few hundred miles, and you should be set.
Old Dec 6, 2004 | 10:44 AM
white lude's Avatar
Default Re: ECU, does it work imediately? (AndyD)
thanks man, thats what i wanted to hear, how does your h22 run now ? have u had it dynoed?
Old Dec 6, 2004 | 10:55 AM
AndyD's Avatar
It runs well. I still have a hesitation issue every once in a while though. I still need to do a tune up on it. I want to check my timing, change my distributor cap and rotor, and wires, and clean my intake filter.
Without replacing these things, my car dynoed at 179whp with an AEM intake, Hondata IM gasket, Carsound cat, and Thermal cat-back exhaust. That's it.
I can definitely squeeze out more HP/performance when I tune it.
Old Dec 6, 2004 | 12:04 PM
spnbb2
Guest
Posts: n/a
from reading your post its sounds as if your still using the h23 p14 ecu?
if so, get a h22 p13 ecu
Old Dec 6, 2004 | 12:12 PM
AndyD's Avatar
Default Re: (spnbb2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnbb2 &raquo;</TD></TR><TR><TD CLASS="quote">from reading your post its sounds as if your still using the h23 p14 ecu?
if so, get a h22 p13 ecu</TD></TR></TABLE>
Oooooh, man, I think you are right!!! lol I think he is using the H23 ECU.
Old Dec 6, 2004 | 12:22 PM
matix's Avatar
Default Re: (AndyD)
Right after i swapped mine i hade a bunch of little bugs i had to work out. The one that made my car almost a 1/2 sec slower in the 1/4 mile was my secondaries staying closed. Once i fixed that the car pulled like hell in vtec. But if your using the old motors ecu i reccomend getting a p13 asap and dont drive the car until you do. If you need a p13 i have one just contact me.
Old Dec 6, 2004 | 01:47 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
On what dyno?
Old Dec 6, 2004 | 01:53 PM
AndyD's Avatar
Default Re: ECU, does it work imediately? (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
On what dyno?</TD></TR></TABLE>
Dynojet.
I beat out a slightly modded 98 328is. He dynoed at 170whp...which is a little low for that car. He ran before me.
Oh, here is a video clip of my ca rin action. That's a Testarossa in front of me. Pay close attention to when we get to the top of the road.
http://www.we-todd-did-racing....DE%3D
Old Dec 6, 2004 | 02:03 PM
LudeyKrus's Avatar
What track was that at?
THAT's the **** I wanna get into! I just don't know of anything around here that's like that.....Guess i'll have to stick to the drags for now.
Old Dec 6, 2004 | 02:30 PM
AndyD's Avatar
Default Re: (LudeyKrus)
That was at Summit Point in West Virginia. Cool track. This event happened last Oct. I went to VIR (Virginia Internation Raceway) in southern Va (Va/NC border) two weeks ago. Now THAT place is AWESOME!!!
Dude, you guys have Road Atlanta down there. You should go there. Do a search and check out their website. I am sure they have a track schedule posted, or will have one very soon.
I was speaking with a guy from NC at VIR who goes to Road Atlanta often. He was raving about it. He said it is a scary track...but fun. I will go eventually. Watkins Glenn and Mid-Ohio are on my list for next year.
turb0hatch04
Mar 18, 2007 01:04 PM
2LiterTurboSeR
Feb 25, 2006 05:15 AM
mck26
Oct 9, 2005 12:47 PM
92LudeSI
Mar 29, 2005 04:45 PM
AndyD
Dec 24, 2003 09:04 AM
