Driver's Side Driveshaft install
Old Sep 26, 2002 | 09:12 AM
satan_srv's Avatar
Default Driver's Side Driveshaft install
Any tips for doing this? How difficult will it be? As far as I know it seems pretty simple...I think there's only a couple of bolts. Thanks in advance.
Also, could a bad driveshaft (CV boot) be causing my car to accelerate choppy and steer somewhat loose?
Old Sep 26, 2002 | 09:51 AM
boomslang's Avatar
Default Re: Driver's Side Driveshaft install (satan_srv)
It's pretty simple. You just need a 36mm socket to remove the axle nut. The easiest way to do it is loosen the nut with the car wheels on the ground. Jack the front up and remove the lower suspension bolts out, then remove the fork. It takes a little muscle to pull the axle from the intermediate shaft though.
Old Sep 26, 2002 | 10:02 AM
satan_srv's Avatar
Default Re: Driver's Side Driveshaft install (Inlinefour)
Something tells me this will be tougher considering I'm lowered and have a bodykit Casue you are saying to jack it up but leave the tires on the ground so it's easier to break, right?
Old Sep 26, 2002 | 10:25 AM
boomslang's Avatar
Pull the centercap from your wheel. Leave the car on the ground. Have an assistant push hard on the brakes. Loosen the nut.
Leaving your car on the ground when loosening the nut gives you the advantage of the friction of the tires against the ground.
Then jack it up to pull the axle.
Old Sep 26, 2002 | 10:26 AM
satan_srv's Avatar
Okay it all makes sense now. thanks for the help
Old Sep 26, 2002 | 10:27 AM
apexii's Avatar
[edit- beat me to it ]
[Modified by apexii, 2:28 PM 9/26/2002]
Old Sep 26, 2002 | 10:41 AM
Sephro's Avatar
Default Re: Driver's Side Driveshaft install (apexii)
I was just going to ask the same question. I have to replace my drivers side CV axle. In the Honda Manual it says you have to remove the lower ball joint? Also does the shaft come out easy on both ends??
Old Sep 26, 2002 | 11:22 AM
apexii's Avatar
Default Re: Driver's Side Driveshaft install (Sephro)
Yes, the lower joint has to be popped. The axle will come out easier on the hub side than the trans side, or thats what i've noticed in the past. The reason for dropping the lower joint is so you can get the axle out, otherwise you cannot remove it.
Old Sep 26, 2002 | 11:27 AM
Greyout's Avatar
this is one of the few cases where brain < brawn.
you really have to knock the crap out of the axle to get it out of the intermediate shaft.
I stuck a ball joint fork between the shafts and hit it with a crow bar.
Old Sep 26, 2002 | 04:38 PM
Turbo Lude SH's Avatar
Default Re: Driver's Side Driveshaft install (JDM LUDE)
I had to stick a pry bar in mine and hit it REALLY hard with a sledge hammer to get it out. Good luck.
Old Sep 27, 2002 | 05:10 AM
Sephro's Avatar
Default Re: Driver's Side Driveshaft install (Turbo Lude SH)
oh yay! You guys are making me so look foward to this!
Old Sep 27, 2002 | 07:17 AM
del_parker's Avatar
actually you don't have to remove the lower ball joint... you can just disconnect the arm from the frame...MUCH easier.
Old Sep 27, 2002 | 07:53 AM
ViZ's Avatar
ViZ
Default Re: Driver's Side Driveshaft install (del_parker)
it can be easy or a pain depends on your luck, and i know mine are going when i get a clunking sound when i am turning like on city streets...
Old Sep 27, 2002 | 09:44 AM
Thats what I did. SInce if you dont have a ball joint puller, you'll NEVER get your ball joint out. At least on mine it was impossible. The passneger side is a little hard to get back into the frame though, but you can do it.
thisguyhere
Honda Civic (2001 - 2005)
Nov 7, 2009 10:01 PM
Tommy_Gunns
Apr 13, 2009 09:39 PM
peshte
Oct 3, 2005 10:07 AM
Immanuel
Oct 2, 2005 12:47 PM
