DIY: H22A VALVE ADJUSTMENT
Old 05-31-2006, 02:26 PM
  #51
moderator emeritus
98vtec's Avatar
Default Re: (Mr.Luder)
yes, you go in sequence. Just like the pictures shows.
1,3,4,2
Old 06-01-2006, 03:52 AM
  #52
skinnyboy's Avatar
I recently done mine, made it som much easier as the engine is out of the car hehe!
Being a mechanic i have the Snap On Tool, and its a godsend. But for you backyarders unless your a tool freak like me or can justify it,just go ghetto, you only will use it once in a blue moon.
heres my tool (ooerr missus)
and engine, nearly ready to go back in!
Old 03-19-2007, 06:51 PM
  #53
integra15's Avatar
Default Re: (skinnyboy)
I just picked up that Alltrade tool pictured above and am about to check the valve adjustment.
But I have a question - if you adjust too tight will it result in increased noise?
Old 04-02-2007, 10:19 PM
  #54
Jacen's Avatar
Default Re: (integra15)
I have a question too, I haven't done any valve adjustments at all the past 70,000 miles. How do you know you need a valve adjustment? If the engine sounds like a diesel engine, does that mean I need to adjust the valves?
Also in the manual it says:
"after adjusting, retorque the crankshaft pully bolt to 220 N-m (22.0 kg-m, 159lb-ft)"
so to retorque the bolt, do I just turn it clockwise to retorque it?
Also what are the torque specs for the Valve cover bolts?
And are these the correct feeler gauges used for the adjustment?
Which valve adjustment tool should I use?
this one
or this one
Modified by Jacen at 11:37 PM 4/2/2007
Old 04-02-2007, 11:33 PM
  #55
smackdown's Avatar
Default Re: (98vtec)
i got a 93 h22a jdm motor ...is it the same specs as h22a1 or h22a4 for valve adjustments..?
Old 04-03-2007, 12:10 AM
  #56
moderator emeritus
98vtec's Avatar
Default Re: (smackdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smackdown &raquo;</TD></TR><TR><TD CLASS="quote"> i got a 93 h22a jdm motor ...is it the same specs as h22a1 or h22a4 for valve adjustments..? </TD></TR></TABLE>
yes
Old 04-03-2007, 12:11 AM
  #57
moderator emeritus
98vtec's Avatar
Default Re: (Jacen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jacen &raquo;</TD></TR><TR><TD CLASS="quote">I have a question too, I haven't done any valve adjustments at all the past 70,000 miles. How do you know you need a valve adjustment? If the engine sounds like a diesel engine, does that mean I need to adjust the valves?
this one
or this one
Modified by Jacen at 11:37 PM 4/2/2007</TD></TR></TABLE>
yes to the feeler gauges, yes to the first valve adjustment tool and yes to the second valve adjustment tool. I have the first one and it works great. Just make sure its for 10mm nuts.
Old 04-03-2007, 04:28 AM
  #58
integra15's Avatar
Default Re: (Jacen)
The one with the red handle. It was easy but took me a couple times to get it perfect.
I made mine on the very tight side, it was the only way to get all the tapping noise out.
Old 03-12-2009, 10:26 PM
  #59
New User
preludeme's Avatar
Default Re: DIY: H22A VALVE ADJUSTMENT
cAn anybody get these photos back up again?? i was like YESS a Writeup and NOOO no photos =(!?!?!
Old 03-13-2009, 05:37 AM
  #60
flyrod's Avatar
The helm manual has pretty good descriptions and illustrations. All you're doing is adjusting a screw and lock nut for each valve. If this seems too daunting, have a friend come over and help.
Old 03-13-2009, 05:55 AM
  #61
mattsnooz's Avatar
You don't want to run any tollerances outside of the values given for exhaust and intake valves. Too tight will not allow valves to open enough as far as I can understand. Withen spec is always the way to go.
Old 03-13-2009, 06:13 PM
  #62
mgags7's Avatar
It's actually the opposite: too tight and the valves might ride the cam a bit and stay open when they're supposed to be closed. Too lose and you lose lift.
One L in tolerance btw.
Old 03-14-2009, 07:23 AM
  #63
Bangher4$'s Avatar
any chance we can get the picture back up?
seems like all the threads these days have dead pics
Old 03-16-2009, 08:50 PM
  #64
Lecco's Avatar
x2 on that one. I also been meaning to do this but can't find pics
Old 03-17-2009, 10:16 AM
  #65
GraphiteMW's Avatar
Bump for pictures!! My h22a is ticking
Old 03-17-2009, 01:23 PM
  #66
Quan_97SH's Avatar
This was the original article posted by Shakes. I saved it when i did my adjustment.
File Type: doc
Old 03-17-2009, 03:52 PM
  #67
GraphiteMW's Avatar
awesome post!
Old 06-28-2009, 09:25 AM
  #68
Bck2BNDoc_K24's Avatar
can it ever be too late to do the adjustment? I've had my Jdm H in for two ears exactly now and never done one, i kinda hear small rattling noises but then they go away.
Old 06-28-2009, 10:04 AM
  #69
218luder's Avatar
the sooner you can get your valves adjusted the better
awesome write up. just got done doing mine
Old 06-28-2009, 10:06 AM
  #70
THXXX
Old 07-26-2009, 02:43 PM
  #71
space cadet
Shakes's Avatar
Sorry, the pics are now back up. They had been hosted on WTDR before, which I believe is no more.
Old 08-14-2009, 05:09 PM
  #72
playdude's Avatar
cool, so im about to do mine BUT noone ever mentioned WHERE to place the feeler gauge? ie. like between the camshaft and rockers? this is basically all i need to do mine,
Old 08-14-2009, 05:49 PM
  #73
95greenlude's Avatar
correct
Old 08-14-2009, 07:13 PM
  #74
playdude's Avatar
so you basically loosen the locknut, set the gauge(.06-.07) between the camhaft and rockers and tighten/loosen the flathead screw until it "clamps" the feeler and lock it?
Old 08-14-2009, 09:31 PM
  #75
I wouldnt say "clamps".....more drags on .006 and .007 does not fit...
Quick Reply: DIY: H22A VALVE ADJUSTMENT
