CV joint
Old Dec 13, 2006 | 08:00 PM
k_lude's Avatar
Default CV joint
i think is the joint or shaft the one with the steering wheel...alrite i did a search on this but they didnt post really on hondas...so how do i know if my CV joint or shaft is bad...when i turn my wheel to the right this is a click sound and my steering wheel shakes on the freeway....so can you guys help out...cause im not sure what it might be.
Old Dec 13, 2006 | 08:10 PM
InvaderTrax's Avatar
Clicking is a sign of bad outer joint. Shaking under acceleration is a sign of bad inner joint. How bad is the freeway shaking? If it's just a tiny bit, you probably just need your wheels balanced. If it's shaking about 1" in each direction, you're got a bad axle. As far as clicking, the louder it is, the worse the axle is. At a certain point, it'll just give out completely and you'll need a tow truck to get it anywhere
Old Dec 13, 2006 | 08:17 PM
k_lude's Avatar
Default Re: (InvaderTrax)
i have two good axles...had a bad one and got it replaced...since i got my new rims they've been doing it...got them balanced twice already...so wats the outter joint problem and the inner joint problems...parts for instance..thanks
Old Dec 14, 2006 | 08:07 AM
CGags13's Avatar
what do you mean?? what parts make the outer and inner joints bad??
Old Dec 14, 2006 | 09:34 AM
k_lude's Avatar
Default Re: (CGags13)
like are the outer joints the axles or somethin?
timcali69
Aug 7, 2007 08:52 AM
blackdelslo
Jan 23, 2005 07:27 PM
dxhatch92
Mar 18, 2004 03:15 PM
dxhatch92
Mar 18, 2004 02:02 PM
madman604
Sep 10, 2003 03:47 PM
